Old 02-04-2012, 11:20 PM
royw's Avatar
royw royw is offline
Vehicle: 2011 Dodge Ram
Rep:39
royw is on a distinguished road
Default Changing a flat
Howdy,
Hit something on the road the other night doing 65 mph. Punched right thru the front tire. 30 seconds later the low tire pressure indicator illuminated, followed shortly by the EVIC showing the tire pressure page. The pressure was dropping fast so pulled onto a side street under a street lamp. Got out and heard the hissing leak, hole was between the middle threads.
OK, time to change the tire.
Grabbed the tools from under the front seat. Impressed with how easy to get to the tools and how well they are packaged.
Grabbed the owners manual. The section on removing the spare tire is missing one important piece of information which is the reason for this post. When you insert the jack extension tool thru the access port and into the receiving cone and turn counter clockwise to lower the spare - it is the female end of the jack extension that you insert, not the male end. This took 40 minutes and then help from a security guard for me to learn.
Once the spare was removed, changing the tire was a breeze.
Putting the tools back was easy. Nice design.
An hour at the dealers and $33.50 later, good as new.
A note is that the spare does not have a pressure sending unit, so the EVIC will complain when you start the truck.
Hopefully y'all want need to try this for a long, long time.
Old 02-04-2012, 11:30 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
An excellent post, it's something that happens rarely but when it does it can be very frustrating. I actually tried everything shortly after getting my RAM just too make sure it all worked properly. Yes, dropping the spare down took me awhile to get sorted out as well.
Old 02-04-2012, 11:37 PM
ramfan1500 ramfan1500 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: trx
Rep:63
ramfan1500 will become famous soon enough
Good info, thanks for the tips. This is what makes forums so great.
Old 02-04-2012, 11:55 PM
MartinJD's Avatar
MartinJD MartinJD is offline
Vehicle: 2011 Dodge RAM
Rep:14
MartinJD is on a distinguished road
Thanks for the info!
Old 02-05-2012, 12:04 AM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Color: Deep Cherry Red
Rep:85
APSTRAM will become famous soon enough
Great information, thanks.
Old 02-06-2012, 10:57 AM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2015 Dodge Ram Crew Cab 4X4
Trim Level: Lone Star
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
Nice info, thanks!!!!!
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
Old 02-06-2012, 11:04 AM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
Excellent post.. my 08 had a ture full size spare my 11' has a donut.. need to check this out and I have not yet.
Old 02-06-2012, 02:47 PM
whatroads whatroads is offline
Vehicle: 2011 Ram 1500 4x4
Trim Level: SLT 4x4
whatroads is on a distinguished road
Thanks for the heads-up on the Jack!
Interesting about the spare tire TPMS. My 08 Wrangler and my wife's 12 Wrangler both had TPMS on the spare tire. Infact, more than once the TPMS alarm has gone off due to the spare tire being low on pressure
BTW - I hate TPMS. It's just another bad idea from our constantly interfering government. I rank it right up there with ABS. These ought to be choices and not mandates. Try ABS sometime when you're off road, pointed down on a big boulder, when the ABS starts to let go, (I put in a bypass switch for the ABS on my 08 Jeep).
Old 02-06-2012, 11:14 PM
MartinJD's Avatar
Rep:14
Never been on a big boulder, but I wonder if this is why I keep almost getting stuck in beach sand even in 4x4...
Old 02-07-2012, 07:46 AM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Thanks for the info.... Great to know....
