Old 02-05-2012, 04:15 PM
Thedodgeboy Thedodgeboy is offline
Vehicle: 2002 dodge ram 1500
Color: Charcoal
Thedodgeboy is on a distinguished road
Default Head gasket leak?
So I am going through antifreeze like it's water but there is no puddle underneath my truck, and in my oil fill cap I have condensation so I think I have a head gasket leak? If anyone has any word on this please let me know! Thanks!
Old 02-05-2012, 04:35 PM
GT's Avatar
GT GT is offline
Dodge Ram Forum
Vehicle: 2002 Dodge Ram
Color: Blue/Silver
Rep:645
GT is a name known to allGT is a name known to allGT is a name known to allGT is a name known to allGT is a name known to allGT is a name known to all
Is your exhaust white? Is water dripping from your tail pipe? Those are sure signs of a blown head gasket. If you are losing coolant that fast it must be going somewhere.
www.Billet-Customs.com
ForumZ Decals & TShirts - Vinyl graphics + other Misc. Goodness!
Old 02-05-2012, 04:54 PM
Rep:2616
The cap having condensation is normal, especially if you do a lot of short trip driving
If there is no gunk on your dipstick & when you look down into your fill tube at the rocker arms, you should be good
You might lay some cardboard on the ground under your vehicle when you park it.
We used to do that to find our leaks & the color & texture of the fluid lets you know where it came from. Chances are it is only your lower radiator hose leaking under pressure.
If it was your water pump, you would find the leak at the very bottom of the pumps shaft, there is a weep hole there, but the fan would likely blow fluid all over the front of your engine & on the underside of your hood, if you are losing that much fluid
Old 02-05-2012, 07:17 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
This is not necessarily true. Plain, clear water dripping from the tail pipe is a normal function of the catalytic converter. When it is the color and smell of coolant is when its time to worry.
Sure it'll suck, but it'll make you a man
Old 02-07-2012, 01:53 AM
Tommycat Tommycat is offline
Vehicle: 2004 Dodge Ram
Rep:22
Tommycat is on a distinguished road
Seen that happen. Yes, water dripping from the tailpipe is normal(unless it's a LOT of water). If you're worried about water in your oil, check your dip stick. If it looks like chocolate milk, that's bad. Watch for white smoke out the tailpipe. Are you missing(engine rough)? Any other symptoms or is it just running through antifreeze. If it's ONLY running through antifreeze, replace your radiator cap. Seen that work once or twice, and it's cheap. When you park check to see if you hear any bubbling.
Old 02-07-2012, 11:58 AM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
Excellent point. If its a lot of coolant running out the exhaust, surely the catalytic converters would have triggered a code and CEL, besides leaking a lot going missing means it should manifest itself very obviously either in the oil, or out of the exhaust.
Old 02-07-2012, 11:07 PM
Rep:22
Yes if it's only running through water, it's simply a cooling system problem. If there are any other symptoms that generally leads you to the REAL problem. Missing could mean the cyl is not getting enough compression, which can happen if your head gasket is blown. Which would add pressure to your cooling system which would eventually fill up with air. Not so much leaking antifreeze as it getting forced out.
Just losing antifreeze though, check hoses, cap, radiator, water pump, and the painful but relatively inexpensive heater core(if you don't do the work yourself, you're looking at better than $1000 in labor, and if you do the work yourself you understand why it's way more than that). Check everywhere for leaks. If you can't find any and there's no other symptoms, it's probably the heater core.
I'm a cheap kinda guy. I try replacing the cheapest first and working my way to the expensive stuff.
antifreeze, condensation, head gasket, leak
