Old 02-06-2012, 03:15 AM
Happilymarrieddad Happilymarrieddad is offline
Vehicle: 2000 Dodge Ram 1500
Trim Level: ?
Color: Blue
Happilymarrieddad is on a distinguished road
Question Scraping when Accelerating 2000 Dodge Ram 1500 5.9L
I just purchased a blue 2000 Ram 1500. The truck runs great and I got it for less than half KBB but it make a slight scraping sound when it driving faster then say 15mph. It doesn't do it when idling. Has anyone experienced this? It almost sounds like there is some scraping somewhere along the drivetrain. I cleaned out the transferbox and rear differential and there was no chucks of metal or dirty fluids. Thx!
By the way, the floor board slightly vibrates with the sound.
Last edited by Happilymarrieddad; 02-06-2012 at 03:21 AM. Reason: adding something
Old 02-06-2012, 03:41 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I would go after the double cardan joint at the back end of the front driveshaft, if its 4wd. Any wobble? it should be stiff, and NO play at all, in any direction. I would also change the front ujoint, too, while its off.(pry on it in all directions) also, the axle joints (pry in all directions, as well.) are probably due, once again, if its 4wd. if its 2wd, I'd definately get after the ujoints on the rear axle driveshaft. Please let us know what'cha find!!!That double cardan is rebuildable, but I wouldn't do anything but take the driveshaft off and deliver it to a driveline specialist, if you haven't got a oxy/acytl torch. it consists of 2 ujoints and a ballsocket assy. (I suspect your ballsocket assy is shot) the ballsocket assy comes as its own kit. Again, if it's 4wd. It should be considerably worse in 4wd.
Old 02-07-2012, 03:41 AM
Trim Level: ?
Color: Blue
Default Reply
I worked all day today and won't get a chance to check the things you said to check until Saturday. Thank you for the reply by the way =). It is 4wd and the scraping isn't any worse in 4wd. On Saturday, I will check the things you mentioned. Also, what does assy stand for? Thx.
Old 02-07-2012, 03:51 AM
knappk6's Avatar
knappk6 knappk6 is offline
Vehicle: 2008 Dodge ram
Trim Level: Big Horn,MonsterMile
Rep:15
knappk6 is on a distinguished road
assy=assembly.
I guess my comment needs to be longer in order to post
35% tint on front, 2 JL 10W1 underseat, Kenwood KVT-514, Green LED footwell lights, Spectre CAI, Nitto Trail Grapplers 295/60R20, HBS 2" Leveling Kit
Old 02-07-2012, 05:58 AM
Nck's Avatar
Nck Nck is offline
Vehicle: 2013 Ram 1500 Laramie
Rep:74
Nck will become famous soon enough
Do you know if that truck ever went in deep mud, or did a lot of offroading?
Because with mine, i had the same issue, but it turned out to be rocks or whatever around the driveshaft, wheels. Went away with a good spray down of the undercarriage.
