04 Defroster issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 02-06-2012, 12:09 PM
troben's Avatar
troben troben is offline
Vehicle: 2004 Dodge Ram 2500
Trim Level: Larimie
Color: Blue
troben is on a distinguished road
Default 04 Defroster issue
Hey guys, been having an issue lately with my heater, randomly the controls stopped working and it will only blow out of the main vents, no defroster, or foot option. Sometimes it will randomly work, but pretty much I have no control over my heater, and being from colorado I definately need a defroster. Has anybody else had this issue, or have any ideas as to how i can fix it? thanks!
Old 02-06-2012, 04:18 PM
ShiftJockey's Avatar
ShiftJockey ShiftJockey is offline
Cummins Driver
Vehicle: 2017 Laramie Crew Cab 6.7L CTD
Rep:124
ShiftJockey will become famous soon enoughShiftJockey will become famous soon enough
Sounds like your HVAC blend door. Unfortunately, it's buried under your dash and not easy to get to.
Michael
2017 RAM 2500 CTD
Old 02-06-2012, 10:55 PM
willysmith willysmith is offline
Vehicle: 2003 Dodge RAM PICK UP 4WD
Color: Claret
willysmith is on a distinguished road
Not expert advice, but I had similar issue with mine - it wouldnt switch from one setting to another very well and was troublesome. I ran my fan (which I am trying to fix see post in the section!)on high as this seems to help the door actuate, and then spent twenty minutes switching the positions from one to another making sure the air flow was moving to each outlet before switching to next setting. This "exercise" seemed to cure my problem and I always swap positions whenever i drive heater or air con, I make sure to exercise them! Maybe I was lucky, or maybe this will help, good luck!
Old 02-07-2012, 12:40 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Actually it sounds like mode door one failure rather than blend door failure. If you don't know already, the HVAC doors and motors that control them in our trucks suck!! It's not so much a matter of if they will break but more a matter of when. The blend door controls the hot air/cool air mixture. Mode door one routes air from the main vents to the secondary part of the system. Mode door two is in the secondary part and routes air either to the floor or the defrost. Sounds like mode door one isn't working to me. The dealer will tell you that the dash has to be pulled to fix it but there is a company called heatertreater that makes a kit with detailed instuctions for repair and it's not terribly expensive. I haven't used them personally but I have read good things about them. You should check out their site and they also have some diagnostic vids on youtube.
Old 02-08-2012, 12:05 PM
troben's Avatar
Trim Level: Larimie
Color: Blue
^ Thank you very much, I think I am going to go with their kit
Old 02-08-2012, 04:52 PM
Color: Claret
Glad to see this info about Heatertreater too! :-)
2004, defroster, heater
