Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 02-06-2012, 06:01 PM
smokinbenelli smokinbenelli is offline
Vehicle: 1998
Color: red
smokinbenelli is on a distinguished road
Default 98 Ram 4x4 steering wobble
Hi guys. I;m new to this site and new to owning a Dodge. I picked up a 98 dodge 4x4 reg cab with the 5.2 auto in it. An older guy owned and it really wasnt driven in the last 2 years. Maybe 500 miles or so. Anyways, it had 75k miles on it when I bought it and now about a 1k more. It is starting to have a slow speed wobble in the steering. It didnt do it untill a couple a days ago when I came around a turn at like 10mph. It has got worse since the start. Online I seen article about the death wobble on dodges, what is the cure? I seen kits online that you can get a new drag bar, ball joints and tie rod ends. Is it worth replacing all or trying to find out one thing at a time
Any input would be great. Thanks
Old 02-06-2012, 06:11 PM
mohawk-ram's Avatar
mohawk-ram mohawk-ram is offline
Vehicle: 2012 dodge-ram quad cab st 4x4
Trim Level: sxt
mohawk-ram is on a distinguished road
welcome to the site,i cant help you with your truck problem but im sure some who can will chime in real soon.
good luck
if u cant dodge it RAM it lol
Old 02-12-2012, 01:47 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
What you're asking is a matter of preference...and money.
I'd suggest you have someone turn the wheel back and forth while you look under there for any looseness.
Then jack up the front end and check both side wheels, up and down, and side to side to check for play.
I prefer to isolate the problem and fix it or modify it accordingly. If there's a bad ball joint, outer universal joint, or any other problem not directly associated with the wobble, then you may wind up doing a lot of work and spending a lot of money to have shiny new parts to go with the wobble.
Old 02-22-2012, 08:50 PM
erhmason erhmason is offline
Vehicle: 1999 Ram 2500
erhmason is on a distinguished road
Check out the track bar ........IF it's bad......replace it with a Moog.
Old 02-26-2012, 05:39 PM
MrCompton MrCompton is offline
Vehicle: 1997 Dodge Ram 1500 4x4
Trim Level: SLT Larmie
Color: Green/Silver
MrCompton is on a distinguished road
Is the Moog thicker than stock? And does it last longer?
