Old 04-11-2012, 09:15 PM
Miami Son Miami Son is offline
Vehicle: 2012 Ram 1500 Sport Crew Cab
Color: Mineral Gray
Rep:26
Miami Son is on a distinguished road
Default My Lockpick is in!
Put my Lockpick in today. Aside from all the crawling around under the truck it really was a plug-and-play install. I took my time since I have a bad back, but an able-bodied person should be able to do this in 3-4 hours. Here's some pics of the highlights.
Rather than run the camera wiring separately I decided to run it inside the sheathing from the electric tailgate lock kit I installed just 3 weeks ago. Would have been easier to do both together had I known back then I was getting this add-on.
This is the harness from the electric tailgate actuator.
The harness runs along the driver-side frame rail. It will be zip-tied to the existing wiring harness.
This was the hardest part of my install, squeezing the camera wire into the split-loom harness from the electric tailgate lock already in place. My thumbs are killing me!
All done running the camera cable in the split-loom and secured to the existing wiring harness. Looks factory, eh?
I brought the camera cable in through the accelerator cable grommet by poking a small hole in it. Once I pushed the cable through I resealed it with some clear silicone.
The cab side of the grommet where the cable came through. More silicone just in case.
Removing the console and radio trim is pretty straight forward. If you use something hard to pry anything off a couple of pieces of tape will help prevent any scratches.
Once you have the shifter trim off grasp the bottom of the radio trim and pull gently. It should come off pretty easily.
Remove the connectors from the backside of the radio trim. No worry as to marking them because each can only fit where it came from. They all have little release tabs that have to be pressed while pulling. Be careful not to scratch anything as it is a bit awkward to get at.
The Lockpick's instructions are actually very good and there's no need for me to cover them here. All connectors fit only where they are supposed to go. There is plenty of room behind the radio trim to mount the Lockpick harness and main module. There is a lot of room under the shifter console, as well. After initializing and firt-run setup, I now have this on my display.
You can turn off the distance markings if you prefer, but it must be done before you close everything up. I like them, though. Not only does the backup cam come on automatically when you put the vehicle in reverse, you can access it at any time from the display screen. You can also switch camera views (in a multi-cam setup) and turn off the camera view with the left side steering wheel control. Haven't tried inputting a destination or watching a DVD while driving yet, but give me a few days.:
Old 04-12-2012, 10:12 PM
TurboCup87 TurboCup87 is offline
Vehicle: 2012 1500 Sport Crew 4x4
Rep:28
TurboCup87 is on a distinguished road
Looks awesome! THX for the write up. Do you know if it's possible to use LP to add cameras to the OEM BU cam? It would be nice to be able to see middle or rear of a trailer.
Old 04-12-2012, 10:41 PM
Color: Mineral Gray
Rep:26
Yes, you can add 3 additional cams with the Lockpick, but only 1 with a reverse view.
Old 04-14-2012, 08:43 PM
mmcglynn264's Avatar
mmcglynn264 mmcglynn264 is offline
Vehicle: 2011 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
mmcglynn264 is on a distinguished road
Can you add some pics of the camera? Also, how is the video when backing up at night. Was wondering, if it's a license plate mount, if the license plate lights wash out the camera at night.
[B]RetraxPro tonneau cover; Mopar Power Tailgate Actuator; CoverKing NEOSUPREME RED w/BLACK SIDES; AMP Reasearch Powerstep; Mopar Molded Splash Guards; Husky WeatherBeater Floor Liners[/B]
Old 04-14-2012, 10:14 PM
Color: Mineral Gray
Rep:26
Here's a pic of the camera. Haven't really used it at night yet, but I will try it and see what it looks like.
Old 04-15-2012, 01:22 AM
Thanks for the pic. That helps alot. If the cam works good at night, I'd rather do that then install one in the tailgate handle. With the tailgate handle one, it's usless if you want to back up with the gate down (all you see is the ground under the truck). Plus with aftermarket in the tailgate handle you need to make sure to have disconnects for it between the tailgate and bed in case you need to remove your tailgate for some reason. Your camera eliminates all those issues! I like it! BTW, you might want to concider blocking out you plate number in the picture.
Old 04-15-2012, 09:46 AM
Color: Mineral Gray
Rep:26
Why? No one's ever showed up on my doorstep because of my plate being posted online and if they did my doormen, Mr. Smith and Mr. Wesson, would greet them.
Old 04-15-2012, 03:46 PM
^^^Good point! Mr. Beretta Storm guards my door and he rides in my Ram
Old 04-15-2012, 04:05 PM
Color: Mineral Gray
Rep:26
Mr. Browning watches my back door.
Old 04-19-2012, 02:14 PM
Miami Son, any chance you were able to check out how the backup camera video looks at night? Got my new 430N on it's way and I'm getting ready to order lockpick and camera. I'd like to make sure the license plate lights don't mess up the back up cameras picture quality, since those two lights shine right at the plate.
