Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
Old 02-06-2012, 08:07 PM
Tex's Avatar
Tex Tex is offline
Vehicle: 2007' 1500 Dodge Ram Quad Cab
Rep:19
Tex is on a distinguished road
Exclamation Flowmasters: True Dual vs. Single in dual out
My husband is currently in Afghanistan and has expressed his desire for true dual flowmasters on his 4x4 Hemi 1500 Ram. I have a 4.7 1500 Ram 2WD and I'd like the same. Problem: The mechanic said it might not be possible to put the true dual kit on with 2 cats and no tips. This is also a project that means the world to me as a surprise for my husband before he comes home. He currently thinks it'll happen AFTER his return.
So, questions on which is better for gas? Sound? Performance? Any advice is appreciated!! I'm not the type to settle for less and you get what you pay for. I have an awesome shop willing to do the true dual for just under $500 for each truck [I've got a friend who's got a 4x4 jacked up 1500 Ram like mine I'm bringing in with me to have the same done on her truck]. So a 3 truck job makes for a great bargain with mechanics.
'Si vis pacem para bellum'
Old 02-06-2012, 08:20 PM
ShiftJockey's Avatar
ShiftJockey ShiftJockey is offline
6.4L HEMI Driver
Vehicle: 2014 Ram 2500 CC 6.4L HEMI
Rep:58
ShiftJockey will become famous soon enough
Not sure what the tips have to do with it. The physical issue is that due to the fuel tank location, it limits the room you have to run a true dual system, with dual cats, dual mufflers, etc.
It can be done but it takes some planning and the pipes will be so close that you may not have room for a crossover or x-pipe.
To get around that, a lot of folks use a single in / dual out muffler with a bit larger Y-pipe to remove the restriction you find with the stock piece. Then you have a nice muffler in place, two tailpipes going out the back and the tips of your choice.
One concern for both trucks that you should be aware of. When you remove the stock system you end up removing the stock resonator at the end of the tailpipe. You could experience some resonance (drone) with an aftermarket system that you won't like at all. One way to avoid that is to make sure the shop puts on some resonators at the back. Later on, if you want to try it, you can cut out the resonators and see how it goes.
Michael
2014 BIG HORN CREW
6.4L HEMI
Old 02-06-2012, 08:23 PM
Tex's Avatar
Tex Tex is offline
Rep:19
Resonators? I've never heard of those. I'm willing to get the single in dual out for the ease of it all but my husband is all for the true dual. He's got me hooked on the idea as well.
I'm curious about the true dual if we were just getting them for performance? No lift on either vehicle. If he's out in the woods hunting in the truck will there be any problems with true dual instead of the single in dual out? I really appreciate the info!!
Old 02-07-2012, 12:15 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I moved this thread into the 'Mod Zone' in the 4.7L exhaust section. I think you will get more response here. If not, it is at least a great place to read about what others with the same engine have done with their exhaust......and there are a lot of posts here.
brad
Interested in one of my mods?
Old 02-07-2012, 04:59 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I hope some of this info helps:
"True duals" does not increase performance. If you keep your stock exhaust but cut out the oem restrictive y pipe, and install a good free flowing one (magnaflow makes one, so does flowmaster, etc...) then swap out the oem muffler for an aftermarket one, it will perform better than "true duals". The crossover (connection between left and right cylinder banks) helps improve exhaust flow.
Now duals with an x pipe or h pipe connecting them together would perform better than "true duals", and likely better than the y pipe setup, but only better thanthe y pipe by maybe a couple hp, so it's really not worth the extra expense and weight. I always have thought the extra weight offset the couple hp gained.
Mufflers:
There's nothing wrong with flowmasters if that's what you want, just be aware they are chambered mufflers, not free flowing, so although they are a slight improvement over oem, they do not perform as well as a straight through type muffler (magnaflow, dynomax, etc...).
Your best bet for mpg, performance, and cost will honestly be a good y pipe (2.5" dual inlet/3" single outlet) to a muffler of your choice (straight through type will perform the best). You can do duals by using a muffler that is 3" single inlet/2.5" or 2.25" dual outlets.
Sound is very subjective. I like the sound of a y pipe and magnaflow, plus it costs less and performs well. Some like flowmasters though. And some just have to have the sound of true separate dual pipes. Not having a crossover(y, h, or x pipe) will hurt performance though.
Sean
Old 02-15-2012, 10:17 PM
Tex's Avatar
Tex Tex is offline
Rep:19
Brad, thank you for the move. I actually came looking for my post to update. I can actually check this area for more mods. Thank you again.
Old 02-15-2012, 10:20 PM
Tex's Avatar
Tex Tex is offline
Rep:19
Mufflers:
I appreciate the information on the pipes and mufflers. I ended up going with the 'single in dual out'. The sound and performance are more than I expected. I feel like I've got a pair of my own. I will be having the same put on my husbands truck next week and having more mods put on from there. Thanks again.
