Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 02-09-2012, 07:26 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
That is really good info! I'm going to have to do some research to see how these systems integrate. I would never have thought the cruise control would be affected by the front wheel sensor(s)....let alone the engagement of the front axles.
brad
Interested in one of my mods?
Old 02-09-2012, 08:25 PM
Bennett15's Avatar
Bennett15 Bennett15 is offline
Vehicle: 2006 dodge ram 1500 big horn
Trim Level: SLT big horn
Rep:45
Bennett15 is on a distinguished road
im not 100% sure but from what ive read and been told by other users. makes sense because ur supposed to be able to shift into 4wd any where to 55mph so getting a speed signal from front wheel would allow it to figure out if its safe to engage 4wd and if its malfunctioning the 4wd would not allow axel to engage? and the cruise would monitor wheel speed to keep the desired speed maintained?
5% tint, 35% Windshield, Airaid intake, Super 44 exhaust, DiabloSport inTune, 24" Strada Wheels, Bakflip G2 tonneau, Groundforce 2/4 lowering kit, Bilstein shocks, Roll pan, Upper and Lower Eylids, Cross drilled rotors, LED interior, 12k Headlight/Fog HIDs, Recon Tailights, Kenwood Navi deck
Old 02-09-2012, 09:34 PM
brad12kx's Avatar
Rep:2581
And this would be able to compare the speed difference between the front and rear wheels to determine if axle engagement is OK within the speed limits of engagement.
That IMO, is Smart!
brad
Old 02-09-2012, 11:59 PM
Bennett15's Avatar
Rep:45
haha im just hoping this fixes it if not im back to square one!!
Old 02-15-2012, 12:40 AM
Bennett15's Avatar
Rep:45
Good new boys the sensor arrived today so i tore truck down and installed it and initially didnt do anything to solve my issues. started truck up turned 4wd same shit t-case locks but hubs wouldnt. same issue with cruise not coming on either. So getting frustrated i put brake and wheel back on took it for a run around the block and what do you know cruise and 4WD now work!! sensor must have just needed to calibrate its self! So if you have any of the symptoms i had i suggest you check that stupid sensor on drivers front hub
Old 02-15-2012, 12:55 AM
brad12kx's Avatar
Rep:2581
Good call on this! And great info. Thanks for posting it for the benefit of all.
brad
