1500 spindles and hubs on an 08 2500 they fit sorta!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-07-2012, 02:49 AM
bigtim44's Avatar
bigtim44 bigtim44 is offline
Vehicle: 2008 ram 2500 2wd
Rep:55
bigtim44 will become famous soon enough
Thumbs up 1500 spindles and hubs on an 08 2500 they fit sorta!!
I've been messing around with the 08 dodge that we a re going to race up at Bonneville salt flats.
I wanted the 1500 5 lug hubs and spindles on the 08,the top ball joint fits but the lower 2500 ball joint is much larger and wont fit the spindle.
02 -05 the swap is easy because you just swap the A-arms and the 1500 spindle goes right on there.that don't work on the 06-09.
So I measured the taper on the 2500 lower ball joint and its 1.5 inch per foot taper ,I then bought a tapered ream and enlarged the lower hole on the 1500 spindle.Well the half ton spindle is now bolted up to my 2008 2500 with the wheel on and everything looks like its going to work.
Here's a photo with 20" steel 5 lug rim bolted on and the truck sitting on its feet.
I have a pair of 2' dropped spindles on the way I'll see if they can be modified to fit like this,I'll post the results.
-Tim
2010 Ram 3500 4DR longbed SLT 6 spd manual 4x4 cummins 6.7 tow pig! EFI BY RYAN Flopro exhaust, Valair twin disc clutch
08 Ram 2500 2wd,6.7 cummins, EFI by Ryan, compound turbos, twin CP3 pumps,Hamilton Cam,ported & polished head by MHP,Hellmann intake.1115 rwhp,1860tq,192.5MPH top speed.
B/DT record holder,El Mirage and Bonneville salt flats.
Old 02-08-2012, 10:18 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
If this works I may have to get me a 2500.... I just have to have it dropped! Would a shorter spring work also?!
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 02-11-2012, 12:32 PM
bigtim44's Avatar
Rep:55
I'll keep ya posted ,I have the dropped spindles in hand,I'll ream out the bottom ball joint holes today and try and get them fitted over the weekend.
I also found out that the early SRT10 ram uses a 3/4 ton brake caliper with a 15 inch brake rotor,a company out in cali makes a drilled and slotted SRT10 rotors for $242 a pair.
cheers Tim
Old 02-17-2012, 08:57 PM
bigtim44's Avatar
Rep:55
Thumbs up
The plan is working so far.... I reamed out the bottom ball joint hole in the dropped spindles (1/2 ton) with the 1.5 inch per foot ream.I test fit a new 3/4 ton bottom ball joint into the spindle.
The spindle was then bolted to the A-arms,then turned through its full range of steering motion,no problems.
I am going with Viper srt10 brakes on the front of this truck.
Here's the truck sitting on the 20 inch steel 1/2 ton wheels
Need to drop the back down now and level the truck out.
Thats it for now,I'll post more pics when I get the rear end down where it should be.
-Tim
Old 02-17-2012, 09:36 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
wow, nice man! I like seeing stuff like this, very creative. I had no idea the heavy duty spindles were so MASSIVE lol.
Sean
Old 05-15-2012, 04:58 PM
MorganM MorganM is offline
Vehicle: 07 Ram 2500
MorganM is on a distinguished road
Are you fabricating a bracket to move the brake caliper so it fits the 15" rotor?
