Old 04-15-2013, 12:21 PM
BobbyDukes BobbyDukes is offline
Vehicle: 2012 Ram 1500 Sport
BobbyDukes is on a distinguished road
I had a whistle in mine. Was the drivers side MIRROR! Sounded like a tea Kettle lol
Apparently a "seal" or something was missing in mine. New mirror put on, whistle has vanished.
Old 12-17-2013, 06:23 PM
Zr440tn Zr440tn is offline
Vehicle: 2011 dodge ram 1500 quad cab
Color: Blue
Zr440tn is on a distinguished road
Default Ram whistle
2011 ram 1500 quad cab with 55,000 miles.
I have been reading these posts about the whistling noise and I am having the same noises.
Other issues that I have had:
TC replaced
Rear diff replaced due to 12 pt pinion nut bulletin
Left and right front CV axles
What I am experiencing is that this whistle is between 30-45 MPH and comes in under acceleration but right when the TC locks, then it stays for a while after letting off the accelerator. I have a feeling that this issue is in most of the dodge ram trucks. I was given a 2012 with 27,000 plus miles on it and the noise in that one was just as bad if not worse.
Old 12-17-2013, 06:44 PM
Asur Asur is offline
Vehicle: .
Rep:4373
TC replaced
Its your transmission cooling lines to the front of the truck, you need to install a rubber piece between the support and the lines. This has been covered in many threads. I have the same issue till I installed my Magnaflow, now I rarely hear it
Old 12-23-2013, 01:23 AM
sonofagunner sonofagunner is offline
Vehicle: 2012 dodge ram
Trim Level: 6
Color: silver
sonofagunner is on a distinguished road
Default dodge whistle
i have the same problem in 2012 ram i know it aint the drive train...i put the truck in neutral and could still hear the noise with slight pressure on the gas pedal
Old 10-25-2014, 11:21 AM
bedrock bedrock is offline
Trim Level: sport
Color: red
bedrock is on a distinguished road
hi did anyone find out what the problem is I have the same noise in my 2011 dodge ram 36000 km on it.
Old 12-04-2014, 12:31 AM
Kindanocturnal's Avatar
Kindanocturnal Kindanocturnal is offline
Color: Black/sandstone
Rep:38
Kindanocturnal is on a distinguished road
I had the same described whistle sound on my 2010 ram at about 30,000 miles it turned out to be a small leak in the exhaust donut. The sound did not seem consistent with an exhaust noise problem but did get more prominent at higher speeds. The dealer warranteed it and the noise went away once repaired.
