Need help with power windows - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-08-2012, 03:28 AM
Sean E's Avatar
Sean E Sean E is offline
Vehicle: 2002 Dodge Ram 1500
Color: Gray
Sean E is on a distinguished road
Exclamation Need help with power windows
OK so my power windows stoped working on my 2002 ram 1500 quad cab. The only way i can get the windows to roll down or up is to control it from the driver side. Im lost and need help, i have changed the fuses and its not on window lock and they still dont work. Does anyone know why and how i can fix it?
Thanks
Old 02-08-2012, 10:47 PM
devans devans is offline
devans is on a distinguished road
Sean E,
This is actually a pretty common issue. Take a look over in the electrical section of the forum and you'll see. As a matter of fact I have the same issue with my 02 quad cab. Chances are your master switch is broken inside. Some have taken the switch apart and fixed it others have installed a new one. I checked with a dealership near me and the new switch is $135.00. Don't bother looking at NAPA, autozone etc.. as it seems it is a dealer only part. Ebay might be an option but be careful. Me I'm probably going to try taking the switch apart and seeing if I can fix it first (I'm cheap) if I can't fix it, well it needed replacing any way.
Good luck and keep us posted.
Don
Old 02-09-2012, 01:11 AM
Sean E's Avatar
Color: Gray
Thank you Don ill try that and i will let you know hoe it turns out.
4.7l, dodge ram, quad cab, windows
