Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 3.7L PowerTech V6 Specific Topics
Old 02-08-2012, 09:22 AM
j.arnold.29714 j.arnold.29714 is offline
Vehicle: 2006 Dodge Ram
j.arnold.29714 is on a distinguished road
Default Won't crank
Hey guys, I've got an 06 Ram 1500 2WD 3.7L. Crappy on gas mileage but I love the truck. I've got an issue though, it won't crank.
When I put the key in the ignition the lights, radio, etc will come on. But nothing when I turn the key to crank. Put the truck in neutral, still won't crank. The battery has 13.5V, and also voltage is going down to the starter as well. The posts and terminals on the battery have been cleaned and put back on, still won't crank. Temporarily, I've got in hot-wired right now to get it started but it takes two people.
I hooked up the computer dashboard diagnostic reader and there were no errors. I'm thinking maybe a sensor has been knocked loose, but the sensor, whichever one it may be, isn't loose enough to throw up an error? Or am I dealing with a Neutral Safety Switch issue?
Last question, can the oil pressure switch, if clogged, keep the engine from cranking? Wouldn't that have put an error code into the dashboard computer?
Thanks guys, love this forum.
Old 03-08-2012, 08:16 AM
mattgindy500 mattgindy500 is offline
Vehicle: 2007 dodge ram 1500 ST 2WD
Color: red
mattgindy500 is on a distinguished road
good luck, i just had my engine temp sensor replaced becuase it would not let me truck start. the sensor kept making the truck think it was over heated and would not alow it to start. by the way what is bad MGP to you? i get 16.5 for the norm. i would like to get at least 17.5 as guys i work with that have V8s of any make chevy ford dodge all get 17+MPG good luck getting your rig back on the road.
