Old 02-08-2012, 12:40 PM
Bocephus660 Bocephus660 is offline
Vehicle: 08 Tundra
Bocephus660 is on a distinguished road
Default can the single bulb head lights be swapped out for dual bulb lights?
i have been looking at new 2500s, and i see that they have two different head lights available. the cheaper SLT model has a single bulb head light (dual filament bulb) and the big horn on up have a dual (single filament bulbs) head light.
if i were to get an SLT, could i swap out the single bulb for a dual bulb light assembly? i know the assembly itself would most likely fit, but is all the wiring there? how about the switch for hi/low beams?
Old 02-16-2012, 12:14 AM
ShawnC13's Avatar
Cheap Canadian Labour
Rep:1808
Bump lets move this up and hopefully someone can help you out
Old 02-24-2012, 09:37 AM
bluestreak2012's Avatar
bluestreak2012 bluestreak2012 is offline
Vehicle: 2012 Ram 1500 Express
Trim Level: ST Express
Rep:18
bluestreak2012 is on a distinguished road
Yes you can the casings are the same size and will fit strait in. my buddy just bought a 2012 Express Crew 4x4 and i took the heads out of his 2011 Lone Star. it plus strait into the factory harness and it will work the same on both trucks. So their will be not cutting in to the harness to get the high beams to work on the SLT with the Big Horn lights.
