Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 02-08-2012, 05:44 PM
9Rockr 9Rockr is offline
Vehicle: 2004 Dodge Ram 1500 4.7L
9Rockr is on a distinguished road
Default Rear Suspension Squeaking
Anyone have an idea what would be causing the squeaking? It's making the noise on both sides, when going over bumps, putting a lot of weight in the bed or pushing down on the sides above the wheel well. Is there something that needs to be lubricated or is it more likely something needs to be replaced? It's more of a nuisance than anything as the handling still seems to be fine.
Old 02-08-2012, 11:56 PM
HemiLonestar's Avatar
Rep:289
Older vehicle, bushings start to wear, etc. Every leaf spring vehicle I have ever owned squeaks in the back once it gets up in miles.
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red" (Mods list in profile)
2006 Charger R/T "Little Red"
Old 02-09-2012, 08:22 PM
Ok, sounds about right, can they be lubricated or is the only way to fix them to replace them?
Old 02-09-2012, 11:08 PM
Rep:289
You can probably try forcing some lithium grease in between the leafs and maybe where the bushings are. Hell, even poly bushings squeak, that's why they give you that lube with the bushings before you install them.
"Big Red"
