Old 02-08-2012, 06:49 PM
Rug 15's Avatar
Rug 15 Rug 15 is offline
Vehicle: 2012 RAM 1500 ST
Rep:53
Rug 15 will become famous soon enough
Default rough country lift kit questions...
so i have a 2012 1500 st. wanting to do a small lift. was thinkin of a leveling kit... then i found http://roughcountry.com/suspension/4...ram_combo.html that... wondering if this is a good idea. as far as.. will it effect gas? will i have to re calibrate mph? what about steering affects? and any vibrations even in 4wdrive? it says its a 3.75 inch lift. which basically is a 2 inch block and a body lift as well... thanks for the help
Old 02-09-2012, 12:13 AM
2k84by's Avatar
2k84by 2k84by is offline
Vehicle: 2014 Dodge Ram 1500 SLT
Color: silver
Rep:19
2k84by is on a distinguished road
It will effect your gas mileage, however, depending on your driving habits, it probably wont be noticeable. When you lift a vehicle it becomes less aerodynamic therefor requiring more gas to continue at the same rate of speed. Again, probably wont be noticeable.
No, unless you buy larger tires, you will not have to re-calibrate mph.
Steering should be similar to stock.
Some trucks vibrate with under a 2" lift, others wont vibrate until almost 3". It's hard to tell for sure until you install. Body lift alone wont effect your ride since you are not altering the ride height at all, only the body height.
Old 02-10-2012, 11:11 PM
Troy. Troy. is offline
Vehicle: 2011 Ram
Trim Level: Sport CC 4x4
Color: Bright silver metallic
Troy. is on a distinguished road
I just installed my RC 2.5" front and 1.75" rear leveling kit tonight, went really well. Wheel alignment tomorrow and I'll let you know what I find for problems, hopefully none.
Absolutely love the look!
