Anyone running 22's?? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-10-2012, 07:07 PM
5280RAM's Avatar
5280RAM 5280RAM is offline
Vehicle: 2012 Dodge Ram 1500 4x4
Trim Level: SLT Big Horn
Color: Mineral Gray
Rep:43
5280RAM is on a distinguished road
Originally Posted by NWRQC View Post
Long as the offset of the wheels is good you'll be good to go.
How do I know what offset I need to avoid issues??
THANKS EVERYONE FOR ALL THE INFO!!!!!!!!!
Old 02-10-2012, 08:21 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
Any offset that places the inner lip of the wheel at the stock location or out (lower offset). As wheel width increases/decreases the offset needed will change. So with a 9.5" wide wheel you would need and offset 0f +12 or lower to have the same inner clearance. Since you are going to run a 285 tire you will be fine. If you were to run a wider tire you might need a spacer. I would look for a wheel that has a -0- off set to -20mm offset if you want a wider stance and the tire to stick out a little.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
Old 02-10-2012, 11:53 PM
5280RAM's Avatar
Color: Mineral Gray
Rep:43
Cool. I'd prefer it to stick out as little as possible so I'll look for something closer to a -0- offset.
Thanks again for your help...now just need to save some more pennies
