United Radio
Old 02-09-2012, 01:48 AM
ff169nfd ff169nfd is offline
Vehicle: 1996 dodge ram 1500
ff169nfd is on a distinguished road
Default oil consumption 5.7 hemi
I have an 05 hemi who likes her oil been using mobil 1 5w-20 right out the box and used the oil since day one any new ideas i have all the techs and myself stumped not a like of smoke from the tail pipe any one.. buehler???
this is the last of the non mds engines as i know it so want to keep her going long and strong .just too much damn fun
Old 02-09-2012, 04:08 PM
Knuckles Knuckles is offline
Vehicle: 2003 Dodge Ram 2500 5.7 4x4
Trim Level: SLT Heavy Duty
Color: Gun Metal Gray
Knuckles is on a distinguished road
How much oil is it losing? You checked for leaks? Also look in the air cleaner / throttle body for oil, you might be getting some blow by.
Old 02-09-2012, 06:41 PM
Daytona1445's Avatar
Daytona1445 Daytona1445 is offline
Vehicle: 2005 Dodge Ram
Trim Level: Daytona
Color: GoMango
Rep:12
Daytona1445 is on a distinguished road
What you think is too much is probably way different than what dodge will tell you.
If I remember correctly acceptable to dodge is losing a quart between oil changes.
As said above check your throttle body and see how dirty it is. You might be pulling just enough to not see smoke at idle or driving.
Old 02-10-2012, 03:52 AM
thanks for the reply guys it is losing about 3 qts in between oil changes throttle body is clean leak down and the works tested fine and no performance issues at all. the air box has no residue in it as we can also tell. when i did the tune up last even the plugs looked good however we still changed them out to the autolites.The only other issue we have ever had was when the egr failed and was promptly changed under warrantywith a software update as well
Old 02-10-2012, 10:37 PM
SawdustJ's Avatar
SawdustJ SawdustJ is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:22
SawdustJ is on a distinguished road
What's the mileage on the truck? When the plugs were changed, were any of them fouled? What about the oil pan drain plug, is it leaking/dripping?
You could always do a compression test on each cylinder to see if something is out of whack there.
Saw-
Mods: Extang Tri-fold Soft Tonneau Cover, Bed Liner, Volant CAI
Old 02-11-2012, 02:20 AM
chefred112's Avatar
Rep:656
I burn through a lot of oil myself..but im hard on her....
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
