Old 02-09-2012, 11:54 AM
grog grog is offline
Vehicle: 2011 Ram 1500
Trim Level: Outdoorsman
Rep:17
grog is on a distinguished road
Default EVIC display dimming
The evic display in my ram seems to randomly dim itself at times, there doesnt seem to be any pattern to it, im wondering if it supposed to do this, or is there a setting that i may have accidentally turned on to make it behave this way?
Old 02-09-2012, 12:00 PM
Macfhionghuin's Avatar
Macfhionghuin Macfhionghuin is offline
Vehicle: 2011 Ram 1500 Crewcab 4X4
Rep:40
Macfhionghuin is on a distinguished road
The dimming goes from daytime to night,mine will change if I drive thru a shaded part of the road,then back when out in the brighter light.It,s a little too sensitive...doesn't have to be dark for it to change...hope this helps.....Rob
2011 Ram 1500 CC Sport 4X4,
Mods..CAI,14" Magnaflow,color matched tonneau cover,BedRug,debadged,b-piller decal removed,Egr Bug-deflector,Plasti-dip wheels and grill,short antenna,Custom grill tailgate and steering wheel badges,painted calipers& engine cover,Mopar slush mats
Old 02-09-2012, 01:34 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Color: Deep Cherry Red
Rep:85
APSTRAM will become famous soon enough
If you have the headlight switch on auto then your lights may be going on when in a shaded area which in turn affects you display based on you dimmer setting.
Old 02-09-2012, 01:47 PM
Rep:17
ahh, that makes sense, i wonder if the light sensor could be a bit dirty, anyone know where it is?
Old 02-09-2012, 02:20 PM
Rep:40
It's on the dash,out where the dash and windshield meet.You'll see a small dome,that is the sensor.It read the amount of light and this leads to an adjustment of dash light level.You can try it on a bright day by starting your truck.look at your dash lights, then take a piece of cardboard and cover up the dome sensor,in a second or two your dash light level will change,uncover it and they will return to the original light level ......Rob
mmullengs mmullengs is offline
Vehicle: 2014 Ram 1500
Color: Fire Red
mmullengs is on a distinguished road
I believe the dome shaped plastic in the center of the dash near the windshield is the light sensor
Old 02-09-2012, 02:33 PM
Rep:17
ok, thanks all.
Old 02-09-2012, 03:28 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i never gave a thought to what that little thing was. learned another new thing.
Old 02-13-2012, 02:38 PM
South Dakobra South Dakobra is offline
Vehicle: 2011 Dodge Ram
Color: Deep Water Blue Pearl
South Dakobra is on a distinguished road
I've had this same thing. And yes I use the auto headlight function. So it makes sense. Thanks guys.
