Old 02-21-2012, 08:23 PM
micar71 micar71 is offline
Vehicle: 2011 Dodge Ram
micar71 is on a distinguished road
I would think that you could just use some POR 15
http://www.por15.com/
CRAP!!!! I'm going to get off this forum. Just when I think I'm good to go, someone has to post something that I want to buy and try. Y'all are going to cause me to drain my bank account. GTyankee, have you tried it?
Old 02-22-2012, 11:50 AM
Originally Posted by dkerr24 View Post
The rust spots bothered me enough that I slid under the truck with a can of black Rustoleum and sprayed over the rusty spots on the rear axle. Didn't even sand the rusty spots beforehand. Looks good now.
Crawl under any Chevy or Ford truck, you'll see rust on the driveshaft as well. Surface rust like that is really not an issue.
Darin
If that was your first time doing that, then I guess I should have mentioned earlier that several light coats should be applied, to create a good, solid barrier.
Old 02-22-2012, 12:33 PM
Originally Posted by DRamrod View Post
Does anyone have any insights to dkerr's idea? I'm thinking about doing this the next time its over 50 degrees out here. I know not sanding anything down can be kinda tricky.
DRamrod, if the rust is not any worse than the photos posted by others on this thread, I wouldn't worry about sanding any of the rust.
1. Make sure it's clean of dirt, excessive road tar, etc....
2. Make SURE it's DRY.
3. Make SURE it's DRY.
4. Make sure the temp is around 68 degree or higher (you don't want super tiny bubbles forming - depending on how close you spray and how heavy). Also, BE PATIENT!!!! Wait until spring if you have to. I promise you that the underside of your truck will not crumble between now and then.)
5. Make SURE it's DRY.
6. If you don't have a garage, then buy a six pack of beer for your buddy that does have a garage and tell him how he's your best friend for allowing you to use his garage.
7. If you don't have a best friend, er... I mean access to a garage, then place jack stands under your truck and remove both back wheels.
8. Steps 6 & 7 are dependent on whether or not it's windy and how much time you want to spend GENTLY cleaning off the wind blown over spray from your aluminum rims (It was a big pain in the rear).
Okay, these next few steps seem silly, but for those of you that have rushed in to something followed by regret, you'll appreciate this:
9. Crawl under your truck with a good light source and see if there is anything the paint might land on or over spray on to (under body sheet metal, muffler, yolk, joints) and ask your self if you can live with spray over on these parts.
10. Before spraying, check your nozzle.
11. Be patient and spray one light coat on everything you want painted.
12. START WITH AN AREA THAT IS NOT SO EASY TO SEE ON A DAILY BASIS, so if you screw up, it's not so easy to see on a daily basis.
13. Repeat step 11. Depending on the temperature and humidity, you don't have to wait until the paint is completely dry before applying another coat.
14. Humidity and temp can play a factor. I grew up in west Texas where the air was like holding your face close to the opening of an oven door (dry and hot). Now I live in the Dallas / Fort Worth area, where it is insanely humid.
Plain Rustoleum spray paint worked fine for me 17 years ago on my old truck. As mentioned above by another member, Rustoleum makes a paint that actually stops rust dead in it's tracks. I did not know this and I would recommend it's use.
I really hope this helps and good luck! Post pics
Old 02-22-2012, 01:30 PM
true blue true blue is offline
Vehicle: 2011 dodge ram
Trim Level: laramine
Color: blue
true blue is on a distinguished road
I have the same problem with mine ,the shaft is flakin chunks about a 16 th thick
Old 02-22-2012, 02:41 PM
...holy cow!!! Did you take it for a swim??? Knock off the flakes. Steel brush it. Paint it to seal out water and air. Make sure you treat anywhere your steel brush and paper hit it
Old 02-24-2012, 01:45 PM
pearl207 pearl207 is offline
Vehicle: 2011 Dodge Ram 1500
pearl207 is on a distinguished road
does anyone know of an alternative to spraying on a rust inhibitor? I was looking at using a product that you could wipe on with a rag since it's so difficult to spray while lying underneath the truck and with a rag you can reach all the areas particularly on the driveshaft.
Old 02-24-2012, 02:36 PM
DRamrod DRamrod is offline
Vehicle: 2013 Ram 1500 Big Horn
Trim Level: QC
Color: Cherry Red
DRamrod is on a distinguished road
micar71-
Thanks for all the great information!! Do you have a link of a product that you'd recommend? Rep points heading your way!
'13 QC Big Horn 4x4 8spd - 20% tint, Truxedo, Putco Mirror covers, Nerf Bars
Old 02-24-2012, 06:59 PM
As posted by GTY. I haven't tried it but it looks good. I'm probably going to use some this spring. If anyone gets to it before I do please follow-up with your thoughts. Points to GTY for sharing.
Old 02-24-2012, 07:01 PM
What color is your truck?
Old 02-26-2012, 03:32 PM
DenDen's Avatar
DenDen DenDen is offline
Vehicle: 2011 ram 1500 4x4
Color: Hunter Green
DenDen is on a distinguished road
Somebody mentioned POR15,this is the best 'paint over rust' paint I've ever used.Don't get it on your skin,it's like getting a tattoo.That means its good.Brush it on.It covers way more area than any other paint.
2011 Dodge Ram.Hunter Green Crew Cab,Hemi.20 inch wheels.Bought August 28 2011.
