Old 02-09-2012, 07:37 PM
draken's Avatar
draken draken is offline
Vehicle: 2010 Dodge Ram 1500 CC Bighorn
Trim Level: Bighorn. SLT
Rep:19
draken is on a distinguished road
Default sub question!
Hey,
so I just picked up some Alpine type e's . Two 12". I'm going to buy a box and put them under my back seats. I was wondering if I'm just sticking withmy stock stereo (1.5 din) and I also have a amp I got, will I need to buy anything extra to have this work ?
Zone 6" Suspension with 5" rear, Bilstein 5100s, Toyo M/T 315/70/18, 18x10 MotoMetal 967s, Bushwacker Pocket Flares, Flowmaster 10 series, Diablo Trinity With Hemifever Tune, Drop in K&N Filter, Retrofitted headlights, 5k morimoto HID, 6k Fogs, Metal Tonneau Cover, Plastidipped Bumpers and Grille
Old 02-10-2012, 07:45 AM
yates367's Avatar
yates367 yates367 is offline
Vehicle: 2006 Dodge Ram 1500 Quad Cab
yates367 is on a distinguished road
You will need to buy some hi-level RCA adaptors to hook your amp up to the radio if the amp doesn't have the hi-level built in. This adaptor wires into your factory radio speaker outputs and converts them to RCA to plug into your amp. You will also have to tie into the fuse box for switched power. You want to use a fuse that is only hot when the radio is on... or test for the switched hot wire at the factory radio harness.
This can create a popping noise through your subs when turning your truck off.
