Old 02-09-2012, 09:46 PM
razbilljr razbilljr is offline
Vehicle: 1999 dodge ram 1500 sport
razbilljr is on a distinguished road
Default top gun Lift kit
I have been reading post on this forum for a couple weeks now and decided it was time to join.
I recently bought a 1999 ram 1500 sport with the 5.2 in it and would love to lift it up a little bit. I have seen alot of people talk about topguncustomz and found a 3" lift kit with shocks.
http://www.topguncustomz.com/Store/G...iview=25473996
I dont really know anything about lifts so i was wondering if this kit is something worth buying while on a slim budget, will I need to purchase other stuff to make it work or is this all i need? How difficult is it to install? I just drive my truck around town and dont go off roading just want a nice looking truck. All input is appreciated thanks.
Old 02-10-2012, 06:22 PM
also if anyone has a sport with a 3 inch lift could you post some pics
Old 03-13-2012, 03:17 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
I don't like spacers over 2" without longer control arms over 2" you start to loose height due to axle being pulled back. My advice is to just use a 2" spacer in front and leave the back stock. Then if you want more height a body lift in do those and a set of 35" will look sweet.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
Old 03-20-2012, 11:21 PM
ramz02 ramz02 is offline
Vehicle: 1998 Dodge Ram
Trim Level: SLT Laramie
ramz02 is on a distinguished road
I got a 1998 2wd with a 3" spacer in the front and it works fine
1998 Dodge Ram 1500 - 2WD 3" level w/ 1.5" rear block
Old 03-25-2012, 08:26 PM
Color: Green
Rep:31
Well 2wd and 4wd are not similar in design at all. What causes the problem is the control arms get too short as the axle being pushed down the arms stay the same length and causes the axle to be pulled back. Once you go over 2" spacers on a 4x4 ram you start to loose lift so over 2" you need longer control arms.
Old 03-28-2012, 11:19 AM
2000DirtyDodge 2000DirtyDodge is offline
Vehicle: 2000 Ram 1500 Club Cab SLT 5.9
Color: Ugly Maroon
2000DirtyDodge is on a distinguished road
What size tires are you running on your 2wd? Ive been thinking about doing the same lift as you. I have 265/70/17 AT's right now. I would like to lift mine an eventually throw on a set of 285's or larger. Hows yours sit an look?
Any issues with the lift kit an steering on the 2wd?
