fuel guage not working - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 02-10-2012, 05:32 AM
rhalbert rhalbert is offline
Vehicle: 1997 ram 4x4
rhalbert is on a distinguished road
Default fuel guage not working
just change fuel pump bought a used one so far pump works fine but it shows gas being empty its a 1997 ram 1500 it worked before the float seemed to be free i alined the arrow up with the tank any help
Old 02-10-2012, 11:28 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
The used one probably had a bad sending unit also, you could of bought a new pump for 130 bucks with a lifetime warranty. But it can be the gauge it self, their is no real way to test other then replacing them.
I can tell you one thing I drove for many miles with a broken gauge and so did the preivous owner and I can tell you it was amazing when I replaced my pump to see a working fuel gauge, I still get tickled by it.
Old 02-11-2012, 08:02 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
There may be a problem with the float. Even though the arrows are lined up it may have jammed on the way in.
Or there could be a crack in the float and it sank to the bottom of the tank.
Sonoctavio just replaced his and posted pics of the pump under a thread called, best way to replace the fuel pump. The float should just pop off and you can replace it. I usually plug the entire unit in and test the float/level before I install it.
