Old 02-10-2012, 11:13 AM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
Default Was the exhaust manifold issue limited to the 2009's?
Hi folks -
I'm suspicious that I might have an exhaust leak (driver's side exhaust manifold) but can't be sure. I'm planning on having it checked next time I bring it in, which is a rare occurrence.
What's leading me to believe I might have a small leak is that, some time ago, my mpg's went off a cliff. While it's right around the time I switched to cooper zeon's, I can't really attribute the drop in mpg to just the tires and my heavy foot. Seems like I lost 2mpg instantly, and nothing with the truck changed (and this is before winterized gas). So, I thought it might be running a little fat given the exhaust leak, etc.
Was the problem of manifold bolts breaking limited to the 2009's?
I don't see any broken bolts, but I know that sometimes these leaks are hard to detect. I don't see any visual clues either - just hearing it on cold startup....
Thanks in advance -
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 02-10-2012, 12:06 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If it's an exhaust leak then it would be audible after the truck is warmed up, you say you only hear it when started cold, so that's likely the lifters tapping.
I lost ~1mpg when I went to cooper zeons.
I don't really have an answer for the question you asked, sorry.
Sean
Old 02-10-2012, 03:08 PM
Turbovsix's Avatar
Rep:83
Thanks - yeah, it doesn't sound like lifter noise to me, but then again, I can't be sure. I think I'm overthinking this one.
Yeah, lost a little mpg with the zeons, but they're a great tire so far otherwise.
Rich -
Old 02-10-2012, 03:25 PM
Rep:2657
I had to take my '09 Ram in for a constant ticking
the exhaust manifold was cracked
Old 02-10-2012, 04:38 PM
Turbovsix's Avatar
Rep:83
I'll check it again today because I am getting a slight ticking when warm as well - I attributed it to the general noise of the engine running. Sounds more like an exhaust leak when cold and then it calms down, but the tick is still there. I'll probably end up having it checked anyway next time it was in. I don't have any outstanding recalls for my 2010, and I believe that the manifold bolts were a recall on the 09's (not sure if they were just an rrt or not)....
Rich -
Old 10-30-2012, 01:50 PM
jeepers's Avatar
jeepers jeepers is offline
Vehicle: 2010 Ram
Trim Level: Big Horn 1500 Crew
Color: Lets Go Mango
jeepers is on a distinguished road
bringing this thread back from the dead........lol......i just found a broken exhaust stud on my 2010 big horn at 45000 mi and i picked up a ticking that goes away as it gets warm also seems like im loosing power
Old 05-30-2013, 07:34 PM
Rammers Rammers is offline
Trim Level: slt big horn
Rammers is on a distinguished road
I took my 2010 Ram 1500 Big Horn in with a tick at 41000 today and it was broken manifold bolts which they fixed under warranty.
