Old 02-10-2012, 12:47 PM
ppl4peace1191 ppl4peace1191 is offline
Vehicle: 1996 Dodge Ram 1500 V8
ppl4peace1191 is on a distinguished road
Default Water pressure build up?
I have a 1996 Dodge Ram 1500 5.9L V8 2WD Pickup. The problem is that it has been holding water pressure in the return hose for the radiator and it has been overheating. I have replaced the water pump and the thermostat. I am thinking that it may be one or both of the head gaskets but I'm not sure. would like another opinion before i continue with this project. Thanks
Old 02-10-2012, 01:00 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
When you say return hose, does that mean return to engine or return to radiator? Maybe a blocked/clogged radiator? I don't see how a leaking HG could cause water pressure buildup.
Sean
Old 02-10-2012, 01:02 PM
Default 1996 Dodge
It is the return hose to the radiator
Old 02-10-2012, 01:08 PM
snrusnak's Avatar
Rep:1385
I'd check to be sure the radiator isn't clogged then. Other than the tstat and WP, there must be a clog somewhere if it's building pressure. Should not get higher than i think 16psi.
Sean
