Old 02-11-2012, 01:05 AM
Silverstar777's Avatar
Silverstar777 Silverstar777 is offline
Vehicle: 2014 Dodge Ram
Rep:19
Silverstar777 is on a distinguished road
Default Battery as performance upgrade?
I have noticed more than once that when changing a battery in my other vehicles, there was a considerable performance increase after the new battery was installed. I attributed this to increasing the performance of the electrical system that newer vehicles are so dependent on. What do you guys think about the battery as a source of performance?
Old 02-11-2012, 02:39 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
It has to do with resetting of the ECU and not the voltage from the new battery. You can get the same result by disconnecting your battery to allow the computer to reset. When you reset the computer it goes into a learn mode while it learns your driving style and makes adjustments to run ideal (emission, fuel economy, air/fuel ratio, etc).
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Carli
Old 02-11-2012, 02:40 AM
Rep:2657
I don't know how many Cold Cranking Amps your Ram battery has, but i do know that the newer Rams have more than 650 CCA
I don't know if they have 700 or 750 CCA
but they must have changed it for a reason
Old 02-11-2012, 06:59 AM
jjz28's Avatar
jjz28 jjz28 is offline
Vehicle: 2007 1500 4.7
Trim Level: SLT TRX4 Offroad
Color: grey
jjz28 is on a distinguished road
I had a camaro that i could tell when the battery was losing power because the car would not run as good. I guess my charging system wasnt too good. Charge the battery or get a new on in it and it would smoke off the tires until it would start getting weak again. I guess the fuel pump didnt get as much power and the electronic ignition/coil wasnt giving as good as spark.
Old 02-11-2012, 03:48 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
I considered mine a MOD, Its a Die Hard Platinum P-2 Group65, bada#% battery.
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 02-11-2012, 07:34 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
i have no idea if it will give you any performance enhancements, but the best battery for the money hands down is interstate. no two ways about it.
Old 02-12-2012, 10:45 AM
Rep:19
I just put an interstate in my other vehicle (Honda Pilot). There was a considerable increase in performance, which is why I asked. I understand the re-setting of the computer, but I do that occasionally and never see any noticeable difference. This was very noticeable.
Old 02-12-2012, 10:57 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If the battery is bad or going bad it could cause poor performance, but all batteries (in good condition) will provide the same power basically. I think cars actually run on ~14 volts, not 12 volts like most people think. Taking a good battery and replacing it will not increase performance. Taking a bad or almost bad battery and replacing it may give the illusion of "increased" performance, but it's just returning the performance to normal. Also like said above, resetting the pcm has some to do with that illusion as well.
Sean
Old 02-12-2012, 07:13 PM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:64
Also the sensors and ecu are low draw so the alternator should pick up any drop in voltage from a battery on its way out. Thats why its best to replace the battery as soon as you notice that it's getting weak. Alternators are not designed to run at 100% and they will burn up doing so because of a bad battery.
Old 02-13-2012, 11:35 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
After i swapped to a large AGM and HO alt i notived anout .5 MPG increase around town, no notice in erformance gains though. I drive practiacally the same route at the same time every day so i always notice the little mpg stuff because its a repetitive routine for me.
2011 Big Horn 4x4 -SnowWhite-
