Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Dodge Ram Decals
Old 02-11-2012, 09:57 AM
514RAM's Avatar
514RAM 514RAM is offline
Vehicle: 2013 DODGE RAM SPORT QC 4X4
Trim Level: SPORT
Color: BLACK
514RAM is on a distinguished road
Default oil help
Hi guys and gals.....
I have a 2011 ram 1500 with the hemi, i bought my ram from the dealer with 6000kms on it, im now a little under 10000kms and is due for a oil change.I dont know if the oil in it presently is synthetic or not.
So here are my questions... if its not synthetic, can i put synthetic in? What oil do you use? Is royal purple a good oil?
Thanks in advance, Paul
Old 02-11-2012, 10:13 AM
Macfhionghuin's Avatar
Macfhionghuin Macfhionghuin is offline
Vehicle: 2011 Ram 1500 Crewcab 4X4
Rep:40
Macfhionghuin is on a distinguished road
Yes you can put synthetic in your truck.Royal Purple is good oil.Make sure you use the 5w20 weight oil.I switched at 1000Km, I use Mobil 1 synthetic,it's another good oil and I find it easier to get as it is sold in many locations......Rob
2011 Ram 1500 CC Sport 4X4,
Mods..CAI,14" Magnaflow,color matched tonneau cover,BedRug,debadged,b-piller decal removed,Egr Bug-deflector,Plasti-dip wheels and grill,short antenna,Custom grill tailgate and steering wheel badges,painted calipers& engine cover,Mopar slush mats
Old 02-11-2012, 10:28 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Oil from the factory is conventional. You can put synthetic in no problem. Realistically any oil off the shelf from autozone or any place like that is fine. Royal purple is very good. Mobil is very good. Amsoil is very good (this is what I use). Like said above, use 5w20.
Sean
Old 02-11-2012, 10:35 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Absolutely, put in some synthetic. I switched mine to 0W20 Amsoil extended drain with a UAPNapa gold filter at 5,000 kilometers. If your changing it yourself the factory filter was a bi%$tch to get off.
sales@revelperformance.com
Old 02-11-2012, 05:20 PM
514RAM's Avatar
Trim Level: SPORT
Color: BLACK
Thanks guys for the help.... i have a few more questions. How many liters of oil does my ram take? should i be using a different weight of oil in the winter vs. the summer? i tow alot does that make a difference in the weight of oil to use? and is there a difference in oil filters>?
Old 02-11-2012, 08:31 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
good question. my book says my truck takes 6 litres of oil. but i just brought my own oil to the dealer (Kendall GT-1 semi synthetic) and they only put in 5 litres. i have to check if it is full, but im thinking the extra litre might be used up in the filter?!?!
Old 02-11-2012, 08:45 PM
Rep:40
The 5.7l Hemi holds 6.6 liters of oil with a filter change.I use either a K&N filter,or the Mopar filter. I use the same weight oil year round,towing won't effect the weight of the oil used in the engine,but depending on how much towing you do ,you may want to change your oil at a shorter interval.....Rob
Old 02-11-2012, 10:25 PM
snrusnak's Avatar
Rep:1388
Like they said^ don't change the weight, use 5w20 (or 0w20 would be fine too). But if towing a lot maybe change it more often. Some oil will be used up in the filter (1/2 to 1 qt) after the first start, so be sure to recheck it after started. Some oil filters ARE junk (like the cheaper frams). I use WIX filters (same as NAPA). Other good choices are mopar, mobil, etc...
Sean
Old 02-11-2012, 10:37 PM
514RAM's Avatar
Trim Level: SPORT
Color: BLACK
Thanks guys...... i truly appreciate it!
