Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 02-11-2012, 09:03 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
Default Best Oil Filter
Has anyone ever tried the Bosch oil filters? I ve always used Mopar (and honestly they really seem fine to me), but i saw the Bosch fileter for 3 times the price as the Mopar filter the other night...i almost got caught up in the "it costs more so it must be better" hype...so i thought id ask!
Old 02-11-2012, 09:10 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I like the Wix filter!!!
Old 02-11-2012, 10:42 PM
Blackzilla's Avatar
Vehicle: 2009 Reg Cab S/B 4X4
Trim Level: Sport/SLT
Color: Black Pearl
Rep:199
NAPA Gold what i use.
Old 02-12-2012, 08:24 AM
Kong's Avatar
Kong Kong is offline
Vehicle: 2012 Toyota Tundra
Trim Level: SR5
Color: Metalic Grey
Kong is on a distinguished road
Check out the Royal Purple filters. I am having trouble finding them locally, but they look really promising.
http://www.royalpurple.com/product-c...le-oil-filters
Old 02-13-2012, 07:20 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Almost any oil filter will be fine. About the only one I wouldnt use if Fram. I like to go to Autozone when they have their Mobil 1 sale going on where you buy a 5 quart bottle of Mobil 1 and they throw in the $12 Mobil 1 filter free. If that deal is not running when its time for a change, I go with Mobil 1 and a Mopar or Wix filter for a 5,000 mile run.
Sure it'll suck, but it'll make you a man
Old 02-16-2012, 02:50 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
Anyone have any info on these?
I picked up a couple at Wally World the other day when I was getting my stuff to change the oil on both the wife's Challenger and on my truck. I'm not having second thoughts, as I've never actually seen or heard of anyone using a Bosch filter before....
I've used many of their other products over the years, and I don't think I've ever had any troubles.
I know the arguments about what filters is best, etc and everyone has their own opinion on this. I'm more interested in personal experience with this product good or bad.
Exco
Bill
Old 02-16-2012, 03:54 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Main things to look for are the following:
1) The filtration level(measured in microns). "Better" filtration is not necessarily better. "Better" filtration (in terms of micron rating) will be more restrictive and your oil pump will be working overtime. It's best to get a filter that has the same filtration level as oem.
2) The type of gaskets. Some cheap filters (like the cheaper fram models) use cardboard instead of rubber. It should be obvious why rubber makes a better gasket than cardboard...
3) Anti drain back valve. Not all filters have this, and if it doesn't then it can cause "dry" starts as it will take longer to circulate oil throughout the engine on start up.
WIX(same as NAPA) is what I use. Mopar's are good. I don't know for sure but would guess that K&N, RP, and Bosch all are good.
Sean
Old 02-17-2012, 02:56 PM
micar71 micar71 is offline
Vehicle: 2011 Dodge Ram
micar71 is on a distinguished road
Agreed, snrusnak. Something else. Some filters use a leaf spring and others use a coil spring. If the coil spring is not supported well, then the filtering system inside the canister may offset. This may cause the filter to not do it's job correctly. My mechanic brother in law stocked only WIX. Bosch is good and so is Mobile 1. Stay away from the four letter "F" word! Yo MaMa may not get you for using that word, but some of us might. Lol
Old 02-17-2012, 03:25 PM
pearl207 pearl207 is offline
Vehicle: 2011 Dodge Ram 1500
pearl207 is on a distinguished road
I personally use Amsoil oil and Filters. They are expensive but based on all the information I have researched, as well as other users, they are reportedly the best on the market. You might spend more, but in the end, you get what you pay for. I have also used K&N filters which are quite expensive but are what they refer to as "high flow" filters. K&N also makes a very good lifetime air filter
Old 02-17-2012, 03:26 PM
snrusnak's Avatar
Rep:1385
Yes that's true the coil spring is better than the leaf spring. The expensive frams are supposedly good but why pay double when you can get a good filter for half? Fram has a genius marketing program...
Sean
