Engine "hiccup" - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 02-12-2012, 04:17 PM
jw11432 jw11432 is offline
Vehicle: 1999 dodge ram 1500
Trim Level: ws
jw11432 is on a distinguished road
Default Engine "hiccup"
when going at higher speeds (55+) my engine, i noticed yesterday, would do a little hiccup thing. to me, it feels like a fuel delivery issue. either a clogging fuel filter, or dying fuel pump. with 214k miles on the clock, i have no idea whats been replaced..anyway, thats my thinking. its not a surge, or jump..it feels like a momentary dead spot, as if its not getting fuel...thats the best way i can describe it, and again only at higher speeds. confirmation?
Old 02-12-2012, 05:03 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Connect a fuel pressure gauge to the fuel rail, if the pressue is lower the 43 PSI +/- 3PSI, replace the pump. If the pump passes then look into an ignition coil problem.
Old 02-12-2012, 05:07 PM
Trim Level: ws
it suppose it would behoove me to invest in a good repair manual for specs reference. :P hopefully a fuel pressure gauge can be rented from oreillys or autozone.
Old 02-12-2012, 05:11 PM
ramvan2500's Avatar
Rep:141
You should be able to rent one, if you have a harbor freight you can buy one for real cheap. My fuel pump died at 125K miles, 16 years old though. Tell me how it goes for you. Ever need help I am more then happy to answer them.
Old 04-13-2012, 02:29 PM
Malfunct Malfunct is offline
Vehicle: 1998 Dodge dakota
Trim Level: plain jane
Malfunct is on a distinguished road
did you get this resolved? I'm having similar problems and its driving me insane!!
Old 04-14-2012, 02:59 AM
The Misfit's Avatar
The Misfit The Misfit is offline
Vehicle: 99 Dakota R/T
The Misfit is on a distinguished road
My R/T did the same thing, it ended up being o2 sensor related..
Old 04-14-2012, 03:10 AM
Rep:2964
with that mileage, i would do a SEA FOAM treatment, just in the fuel system
I wouldn't put it in the oil, you may clean something out that should stay dirty with build up
http://www.seafoamsales.com/
Old 04-14-2012, 03:53 AM
The Misfit's Avatar
Sea foam does work good. Just don't put it in the vacuum lines, take your air hat off, pour it directly into the TB until engine dies, then pour a little more..let it sit 10 minutes, then start the truck, don't rev it much, just keep it running and let it run 5 minutes or so, then rev it, and really burn the junk out.
Old 06-28-2012, 11:26 PM
ryand73 ryand73 is offline
Vehicle: 1999 dodge ram 1500 3.9l
Color: green
ryand73 is on a distinguished road
any body get this fixed
