replaced neutral safety, still have problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-13-2012, 04:12 PM
rikinwyoming's Avatar
rikinwyoming rikinwyoming is offline
Vehicle: 1996 Dodge Ram 1500 4x4
Color: ticket me red!
rikinwyoming is on a distinguished road
Default replaced neutral safety, still have problems
I have a 1996 dodge ram 1500 4x4, 187k on the clock but 25k on motor,,,
Anyway, I have a problem where I get in, turn the key and it just clicks,, put it in neutral, same thing, back to park same thing...
After doing some reading, figured it was the neutral safety switch so I replaced it, still doing the same thing... have plenty power to the battery and charging system...
After trying the key a few times it will start to crank and stop,,key it a few more times it will finally turn over no problem...
Any ideas on this so I can get it fixed,,, it's my daily driver...
Thanks in advance!!
Old 02-13-2012, 05:48 PM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2018 Ram 2500 CC
Color: Delmonico Red
GearHd6 is on a distinguished road
Sounds like a starter issue to me. If it's clicking, you're getting power to the starter solenoid so your neutral safety switch is working fine.
Old 02-13-2012, 05:54 PM
Well it just clicks once when I turn the key, but I agree that I think it's the starter... prolly go get one tonight or tomorrow if the other forum members here feel the same that the starter is most likely the problem!
Old 02-13-2012, 05:58 PM
GearHd6's Avatar
Here's a test, put truck in park, turn key. Do you hear the click? Now put truck into a gear, (not neutral) turn key. Do you hear a click? If not, your safety switch is working fine.
Old 02-13-2012, 06:15 PM
Rep:2964
it could be your ignition switch, if it clicks when you turn the key every time, that is the solenoid & ignition working together.
That leaves a hanging or a bad starter or a loose wire connector as the problem.
You can usually tap the starter lightly with something & IF it is hanging up, it will make it work.
I would start with the starter wiring, POWER & GROUND wires
Old 02-13-2012, 06:17 PM
Did your test as written and no click when it was in gear, so the neutral safety switch is fine,,, of course then I put it in park and it started right up,,,lol
Old 02-13-2012, 06:45 PM
GearHd6's Avatar
LOL, sounds like you've got a dead spot on your starter to me.
Old 02-13-2012, 09:52 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2014 1500 Eco diesel/1982 D150
Trim Level: Outdoorsman
Color: Deep cherry red
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:21
You could have what I had happen to me. I went to start dads 4x4. Turned key to start, click let go of key truck couches and fires up!
