Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 02-13-2012, 10:53 PM
rhinox420 rhinox420 is offline
Vehicle: 96 dodge ram 1500 2wd
Trim Level: n/a
rhinox420 is on a distinguished road
Lightbulb temp gauge show running warm but is not help please
hi i have a 96 dodge ram 1500 pickup 2wd, ok the problem iam having is that the temp guage in the truck when the motor is at operating temp shows any where from 220 to 240 on the temp guage, installed new coolant temp switch because the old [veryold] one broke at the connector, before it broke worked fine no problems, changed thrmosat still samething, changed water pump and still the same, so i took my lazer temp guage and the heads, block, water pump, upper rad hose, and the sensor all show a temp of around 180 but the guage inside the truck shows 220to 240 any ideas thanks
Old 02-13-2012, 10:59 PM
Trim Level: n/a
does anyone think it could be a bad new sensor and just isnt working right or has anyone had the same problem thanks
Old 02-14-2012, 01:19 AM
Trim Level: n/a
Default temp gauge show running warm but is not help please
also does anyone know what a p1391 code is, i think its a dealer code but not sure what its for, if anyone knows???, i cleared the codes and it has not come back up, the other tech at the shop i work at said that maybe some trash got in the way of the crankshaft sensor??? thanks any help would be great
Old 02-18-2012, 11:15 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
This could be a wring/connection issue......or a bad sensor.
P1391 means an intermittent loss of signal form either the Cam or Crack position sensor.
brad
Interested in one of my mods?
Old 06-16-2012, 11:24 PM
cewilford115 cewilford115 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Base
cewilford115 is on a distinguished road
Im having the same problems with my 01, I broke my sensor removing the valve covers... I replaced the sensor, checked wiring and no changes, I unhooked the battery to reset the computer but it will just peg out. I don't even have the engine running and it says its way to hot.
Old 06-17-2012, 12:59 PM
Trim Level: Base
This will sound stupid, but it fixed mine. the plug for the sensor pull it off the sensor and check to see if both female spades are all the way down. those plugs are known to do that stupid stuff. let me know what you find out.
Old 06-18-2012, 09:39 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Its the connector not grounding right causing false reading for temp sensor.
