Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 02-13-2012, 11:08 PM
Hennessey02's Avatar
Hennessey02 Hennessey02 is offline
Color: black/tan
Hennessey02 is on a distinguished road
Default Fabtech 6" Dirt Logic suspension lift
My 2010 Ram is 1 inch lower in the rear. Any suggestions on leveling it?
Old 02-16-2012, 09:13 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
arent the dirt logic kits a coil over kit? IF so just crank the spring seat up till its all level?
2011 Big Horn 4x4 -SnowWhite-
Old 02-17-2012, 03:09 PM
Color: black/tan
Thanks for responding SS4Luck.
Yes it is a coil over system; however it's coilvers in the front only. There are larger springs and shocks in the rear. I also have 2.5" coil spacers on it as well. I think the problem is that the springs are too soft, allowing the rear to drop. I am running 37x22x13 so dropping the front is not an option. Thanks again.
Old 03-01-2012, 06:21 PM
Ryan6900's Avatar
Ryan6900 Ryan6900 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Lonestar
Color: True Blue Pearl
Ryan6900 is on a distinguished road
If I understand you correctly, try blocks. That should do the trick...unless you already have them on. In which case you will need to take them off and place larger ones on. Whatever you do, dont stack them.
Old 03-11-2012, 08:35 AM
SS4Luck's Avatar
Rep:310
^no blocks in 4th gens, they arent leaf spring trucks. You could see if someone makes a coil spring spacer though, that would work perfect
Old 04-11-2012, 04:08 AM
abadiechris abadiechris is offline
abadiechris is on a distinguished road
here you go! http://www.readylift.com/c-272-dodge...ng-spacer.aspx
