Old 02-14-2012, 01:04 PM
turbojimbo turbojimbo is offline
Vehicle: 1999 ram 2500
turbojimbo is on a distinguished road
Default truck wont run
hello all,im lookin for help got a 99 2500 with the 5.9 v8 was going down the road went to pass some one and couldnt do more than 25 mph, relpaced fuel pump, now it wont start so i replaced ect, crank, cam sensor, iac, map, cap and rotor, and spark plugs, used computer off a running turck, new timing chain and gears, new coil and still wont start, i have fuel pressure, compression and spark, all it will do is crank, every once and awhile when you put your foot to the floor and crank it will try to start, i have compresion anywhere from 100 to 120, blue spark, 50 psi of fuel pressure and it will hold it over night, it just wont run
any help is great
Old 02-14-2012, 01:46 PM
Will it start if you spray some artificial fuel down the throttle body , like carb cleaner etc...?
Old 02-14-2012, 01:50 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Will try to start with eather? Have you looked in plenum for oil?
Old 02-14-2012, 02:11 PM
ramfam's Avatar
Trim Level: Base
Rep:21
You have fuel, fire. So no computer issues. The only thing is air and if you have a blown plenum gasket there is little or no vacuum to draw air into intake.
Old 02-14-2012, 02:13 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Holding the throttle wide open during starting shuts off fuel to injectors,= 'clear engine mode' I am inclined to think that it's flooded, if it fires while mashing the motor. pull plugs, spin engine (holding the throttle wide open) and either replace plugs or dry them out with a propane torch. Just don't get carried away with the torch and screw the plugs up...
Old 02-15-2012, 12:42 AM
nope
nope and no
got fuel and fire, ill have to look at the plenum gasket
when i hold the throttle wide open thats when it trys to run
Old 03-03-2012, 11:16 PM
ragtopmfw ragtopmfw is offline
Vehicle: 1994 dodge ram 4x4
Color: red
ragtopmfw is on a distinguished road
wow,, this is exactly what my 94 5.9 is doing and acting like,, did the plenum gasket work,,,thx,,,mike
Old 03-15-2012, 01:30 AM
no the plenum gasket didnt work, im lost, i have had it for a little over two months and can not find a problem, still looking for any help
Old 03-15-2012, 11:25 AM
Ram Lover Ram Lover is offline
Vehicle: 1998 Dodge Ram
Ram Lover is on a distinguished road
You replaced a lot of sensors, but did not mention the TPS......is that one ok?
Old 03-15-2012, 11:50 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
What's the ect that you mentioned? Engine coolant temp sensor?
Since you replaced just about every other sensor, I'd try the TPS as well.
Are you using oem replacement sensors or knock off's? Some aftermarket sensors will not work properly as they're not manufactured to the same tolerances as oem.
Sean
