truck wont run - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-15-2012, 11:58 AM
dodge ghost dodge ghost is offline
Vehicle: 1995 Dodge Ram 2500
Trim Level: Ghost
Color: Flat Black
dodge ghost is on a distinguished road
I had an issue like that where is felt like it was suffocating..The engine wouldnt go past 40mph...Turns out it was the Cat converter...It was screwed..Take a quick look at that, is it in bad shape? While your at it, replace the oxygen sensor as well..Go online and get yourself an Innova OBD-1/2 diagnostic tool, I got one for 225$, comes in handy bigtime!! Once I replaced the Cat converter/ Y-pipe assy, she ran awesome! The Cat was bad and all the internals wwere broken up all inside it causing the engine to basically suffocate!
Old 03-15-2012, 11:59 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Yes good point, it is possible for the cat to cause this. Also possibility is bad fuel pump or clogged fuel filter.
Sean
Old 03-15-2012, 02:31 PM
Trim Level: Ghost
Color: Flat Black
Default Engine not starting
Ugh...The fuel pump, that would suck...I hate the fact that ya have to drop down the tank in order to get to the pump and filter...I wanted to check out mine as well but without a lift Im screwed.. I bought my Ram from an old man who used it on his farm only...Its a 95 but it only had 68K on it( the old man died and his son just wanted to sell it off, so I paid $1500 FOR IT, WHICH WAS A STEAL!!) Its now worth $4500 after all of the modifications Ive done to it since I bought it...Let me know how ya make out bro! A cool site I found was scottykilmer.com- dude is bad ass! Check it out..
Old 03-15-2012, 02:35 PM
snrusnak's Avatar
Rep:1388
IMO it's easier to lift the bed off the truck with a group of friends rather than work upside down over your head trying to drop the tank.
Sean
Old 03-15-2012, 04:05 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:273
namretsud is a jewel in the roughnamretsud is a jewel in the roughnamretsud is a jewel in the rough
An easy check for a bad cat is take the precat o2 sensor out and tie it off to the side and go for a drive. Yah it will make some extra noise but if it runs fine it will tell you that it is a bad cat. Removing the sensor releases backpressure that a bad cat can create. Try it with both side if you have a cat on each side.
Old 03-15-2012, 04:22 PM
snrusnak's Avatar
Rep:1388
Have you actually done this?
The pre cat "upstream" O2 sensors are what primarily affect A/F ratios. I don't even think it would run without them properly in place. Also, I think exposing the O2 sensors to the fresh oxygen while running can ruin them (although maybe that's only when they're hot...not sure...).
Sean
