Old 02-14-2012, 05:01 PM
VirginiaR1500 VirginiaR1500 is offline
Vehicle: 2001 Dodge Ram 1500 5.9liter
Trim Level: Automatic 4X4
Color: yellow
VirginiaR1500 is on a distinguished road
Default Truck bucks,backfires and hesitates upon acceleration
I have a 2001 Ram 4X4 with a 5.9 liter engine with 180,000 miles on it. When I try to accelerate (especially with the engine warmed up) the engine misfires and backfires. It feels like it is misfiring at 55 mph but not as bad as during acceleration. I have replaced the ignition coil, crankshaft position sensor, ignition wire, front oxygen sensor and added two treatments of Seafoam in the gas tank. I also replaced all of the plugs, wires and distributor cap and rotor in the fall. The recently replaced ignition wire has a slight electrical glow tat is visible from the outside cover (it is an Accel wire) when I look under he hood at night.
I do not have current error codes since I cleared them about 200 miles ago. Can anyone tell me what I should be looking for?
Old 02-14-2012, 06:31 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Check for vacuum leak's
Old 02-14-2012, 07:02 PM
The ignition wires sound like their junk . You shouldn't see them glowing at night . Install another set of wires and take a fuel pressure reading
Old 02-16-2012, 12:56 PM
Color: yellow
Default Runs rough and misses when hot
Thanks for the input. I will check for a vacuum leak (any ideas where I need to focus?) and will replace the plug wires. In case I was not clear, I only recently replaced the ignition coil wire with an Accel wire. Previous to that, I replaced all of the plug wires in September of 2011. Thanks again!
