Vacuum lines on front axle - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-15-2012, 08:22 AM
Jas4sons Jas4sons is offline
Vehicle: 1998 dodge ram 1500 sport 4x4
Jas4sons is on a distinguished road
Default Vacuum lines on front axle
Does anyone know a part number for the two vacuum lines that go from the transfer case to the front axle on the passenger side. I think they are plastic I broke the red one while installing my suspension lift and need to replace it. Also is it safe to drive till I get the part I think it just has to do with engaging 4wd so I hope it's ok to drive. Any help would be great thanks
Old 02-15-2012, 08:53 AM
It is ok to drive . Just make sure that if either end is leaking vacuum to plug it off . They do have a conversion kit to change it over to being cable operated . I'll see if I can find the part numers for both .
Old 02-15-2012, 09:45 AM
Thank you very much. I found one diagram but they showed a picture and listed a part name for all the components but didn't label them in the picture. So there were 4 parts with the same name but different part numbers. One of which was the one I needed I think it was a vacuum harness. The line broke right at the angled connector that plugs onto the two prongs on the vacuum shift motor
Old 02-15-2012, 09:50 AM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2010 Ram 1500 CC
Color: Mineral Gray
GearHd6 is on a distinguished road
You can buy that plastic line at the autoparts store. It's just black vacuum line. Just buy enough to do the job and splice it in with small rubber vacuum hose.
Old 02-15-2012, 10:03 AM
OK thanks I'll give that a try
Old 02-15-2012, 11:12 AM
I was unable to track down the vacuum harness , but the manual set up is here www.4x4posi-lok.com
front axle, transfer case, vacuum shift motor
