Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 02-15-2012, 04:19 PM
Falconag Falconag is offline
Vehicle: 2006 Dodge 3500
Falconag is on a distinguished road
Default High pitch whine - TO bearing?
I have a high pitch whine coming from the clutch area of my 6spd tranny. At first it only happened while letting off the clutch and/or accelerating. Now it will also present itself intermittently while idling. Is this the TO going out? I have no slipping in the clutch, just curious how long I can ignore the noise before something blows up or if I should replace it now.
If I break her in half- it almost requires me to replace the plate, flywheel, etc... I hate to do that while the clutch seems to be gripping fine.
Thanks!
Old 02-21-2012, 02:05 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Sounds like the Release Bearing (TO Bearing) is shot.
I wouldn't wait to long on this, as it may already be damaging your pressure plate.
If the clutch is fine, you could just replace the bearing. Although it does require removing the trans, it's not a horrible job. I would only replace the primary clutch item if -
a) It was already at a known high mileage
b) Upon inspection, I determined it 'needed' replacement
brad
Interested in one of my mods?
brad12kx's Avatar
Rep:2581
brad
clutch, throw out bearing
