Old 02-15-2012, 05:14 PM
clive hart clive hart is offline
Vehicle: 1997 Dodge Ram
Trim Level: st
Color: silver
clive hart is on a distinguished road
Default Magnaflow or Flowmaster
Hi, Does anyone know which exhaust config would sound really sweet on my 5.2 4x4 Ram. The duel ends come out on the right hand side just behind the rear wheel. Should it be Magnaflow or Flowmaster. And what do the numbers mean? 40, 50 etc.
Thanks Clive.
Old 02-15-2012, 09:50 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I have a 2 in 2 out magnaflow on my 95, 5.2 L, no cat converter. my head pipes are connected to 2" pipes which are clamped with stainless band clamps. (tight clearances to work with, there, the band clamps are perfect there) These end at approx the front end of the bed which is where the magnaflow begins,welded to the pipes with outershield mig wire. the tailpipes are also 2",welded to the muffler, they reach to beneath the rear bumper.Hangers are on the tailpipes, aft of the axle, and around the magnaflow, this truck is a standard cab, shortbed. An extended cab, or longbed truck would require a couple more hangers, I would think. The muffler is the "crossover, so to speak" and it is mounted with the 'oval' top and bottom. It sounds quite gentlemanly, until the engine is working hard, at 54 Yrs, I'm not much into noisy pipes, however this truck sings... , and only when I want it to. My other truck has a std cab shortbed exhaust system off a factory hemi truck from the cat back, with the 3" pipes, and I'm quite happy with it, as well, sounds quite like my old roadrunner 440, and it simply sounds quiet, but mighty when you want it to, it has original hemi mufflers, too...I'm not much on side exits, it seems someone invariably steps on them and twists them, or they catch on something and crunch shut, when you're backing up. My 2 cents, someone else will have other ideas, I've never owned a flowmaster, no particular reason. Use aluminized pipe or better, and don't go big, they rot out in the UK, too much condensation, from the damp air, I had duals on a Chev there, 89-91, they rotted right off. They have to get good and hot, to lose the acids from combustion, I guess.
Old 02-15-2012, 10:10 PM
Gages1995Ram's Avatar
Gages1995Ram Gages1995Ram is offline
Vehicle: 1995 Dodge Ram
Color: Green/Silver
Rep:69
Gages1995Ram will become famous soon enough
To answer your question about the numbers, they stand for the different series of muffler the companies offer. Personally I think a set of Flowmaster 44's sounds decent on this generation of truck. I'm currently running no mufflers or cats right now... just 3" pipe from the headers straight to the back at 45 degree angles... mine is deep and loud, very loud. If your going for tone, pick the Flowmasters
1995 Dodge Ram 1500 SLT 4x4
Old 02-15-2012, 10:21 PM
Color: 1 Blk,1 Red
Rep:36
A little further info, there Clive, the pipe tha t has to cross over to the other side, for symmetry, is bent immediately aft of the rear axle, and I do not carry a spare tire beneath the truck, I would suggest making a carrier behind the driver, connecting to the bottom of the bed and the side of the bed, anchoring the tire to it via allthread, thru a lugnut hole, and fabricating a wingnut to secure it, and passing a padlock thru the wingnut and another lugnut hole on the spare, IF you carry a spare, I think you probably do, due to MOT. I would be very curious as to what you're paying for a disc, these days, it was 100 quid a year when I was there, ( a pint of bitter was 98 p as well!!) Watch for rust on your sills, the 180 degree bend at the bottom of your doors, and around the tops of your rear wheelwells, if you can, get the seam sealer foam out of those areas, they are built in rust creators, your rear bumper 2 feet either side of center, bottom half, is rust prone, as well... Brake lines are prone to rust out, as well, the first one to go is generally the one hidden behind the petrol tank, you can simply shove a new one behind there, and connect to the tee at the aft end of the tank, and connect the front end somewhere around the left floorboard, the line seldom corrodes there, and you can double flare there, and insert a coupling union. The front brake lines rust out too, but they are at least, visible for inspection. The secondary catch for the bonnet MUST return when released, (most don't, unless lubed regularly,) use grease, it sticks around for awhile. If it doesn't return under spring pressure, your bonnet WILL eventually fly open, destroying the hinges, the hood, and in all likelyhood, the windscreen, and totally ruining your day.
Old 02-18-2012, 06:53 PM
nicraage nicraage is offline
Vehicle: 2001 Ram 1500 4x4, 5.2L
Color: Flat Black
nicraage is on a distinguished road
I think I'm going to run 2 1/2 dual exhaust from my headers parallel to a Flowmaster Super 40 - 8525454. No CAT. From what I understand this muffler with 2 inlets and 2 outlets will act as an X pipe. I hope it's not obnoxious loud.
Old 02-19-2012, 09:25 PM
Ryan421's Avatar
Ryan421 Ryan421 is offline
Vehicle: 2000 Dodge Ram 1500 5.2L V8
Rep:30
Ryan421 is on a distinguished road
I have a single in dual out, 44 series flowmaster. i love it heres a video.
Dodge Ram 1500 V8 5.2L 2WD
Old 02-20-2012, 03:01 PM
Color: Flat Black
Sounds Great!
Is the exhaust stock except for the muffler?
Old 02-25-2012, 05:54 PM
Cody's Avatar
Cody Cody is offline
Vehicle: 1996 dodge ram
Cody is on a distinguished road
i use to have a flowmaster on mine but im now straight piped. very loud but i dont care lol
Old 03-08-2012, 08:22 PM
Trim Level: st
Color: silver
Thanks for your help lads, and and that valuble information. I wish I'd known about the brake hose replacement behind the fuel tank before as I removed the full up tank to do mine. Well its done now. In answer to the question about UK road tax and a pint of bitter, its 118 for 6 months and I think 210 for a year if the vehicle is registered before 2001 otherwise it gets quite expensive. Bitter is about 3.00 a pint.
Old 03-13-2012, 10:40 PM
wulfgar's Avatar
wulfgar wulfgar is offline
Vehicle: 1994 ram 1500 4x4
Color: primer gray atm
wulfgar is on a distinguished road
A little word of advise. I think lol my dodge had the tail pipes dumping out just past the rear bumper and it rotted the bumper out. The bumper had small holes in it when I got it 3 years ago now I can stick my hand in the holes lol.
