Check engine light? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-15-2012, 10:33 PM
Nck's Avatar
Nck Nck is offline
Vehicle: 2nd Gen 2002 RAM 2500 24V
Trim Level: Laramie SLT
Color: Light brown/Goldish
Rep:74
Nck will become famous soon enough
Default Check engine light?
My check engine light just came on, so I went to Auto Zone and had it checked. Turns out it's an output speed sensor (OSS) Circuit Performance.
Explanation
Engine running vehicle in drive and the ECM did not detect and OSS signal.
Probable cause
1. Failed output speed sensor
2. Open or short circuit condition
3. Corroded or moisture in connector.
So where is this speed sensor? I'm going to replace it. If that's the case.
Old 02-16-2012, 11:32 AM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Explanation
Probable cause
The speed sensor is on the outside of the transmission on the drivers side on the extension housing. The thing is if the ECM isn't receiving any speed signal then the vehicle will NOT work so most likely that their is just some water on the wire or the sensor itself is faulty.
Old 02-16-2012, 04:51 PM
Nck's Avatar
Nck Nck is offline
Rep:74
Yeah I was reading how a bad sensor can cause the engine light to go on, and cause the tranny to shift erratic. Which both I have.
Old 02-17-2012, 12:38 AM
Nck's Avatar
Nck Nck is offline
Rep:74
Ok, replaced the sensor. Problem solved.
Engine light went off and my truck seems to shift better than it ever has since I've had it.
Old 02-17-2012, 06:12 PM
ramvan2500's Avatar
Rep:141
Good to hear it's working for you. That sensor is used not only to operate the speedometer, but it is used as a sensor for the ECM to determine the vehicle load and when to drop RPM's to let the trans shift of course this also includes the TPS. Don't forget to give me some rep points, it's been awhile since anyone has gave me some.
If you ever have a problem with the truck my door is open.
