Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Power Wagon
Old 02-16-2012, 10:54 AM
stubie82 stubie82 is offline
Vehicle: 2012 Dodge Ram 2500
Trim Level: Power Wagon
Color: Mineral Gray
Rep:36
stubie82 is on a distinguished road
Default Shifting Concern
Hey Guys, I got my PW a few weeks ago. Still love it, but I have a question. It hasn't been really cold here in Cincy (stupid weather), but I've noticed when I first drive my truck after it has sat for a while, like when I am at work or over night, it shifts really hard from 1st to 2nd. When I turn off the ESC it helps some. It just seems really strange. My 2010 1500 didn't do it. Is it becuase it is a solid axle? I looked under the truck but didn't see anything odd. I want to get some feed back about it before I go to the dealer. I don't want to screw anything up on it yet.
Please let me know what you think.
Old 02-17-2012, 03:17 PM
Color: Mineral Gray
Rep:36
Can anyone help?
Old 02-18-2012, 09:58 PM
camodown's Avatar
camodown camodown is offline
Vehicle: 2010 Power Wagon
camodown is on a distinguished road
Every heavy duty dodge I have drove always shifts like crap when it is cold and you don't let it warm up. My 08 cummins did it but it was usually 3rd to 4th & now my 10 PW does it (1st to 2nd). I usually let the truck warm up if it is cold out. You can get it checked out but, they probably won't be able to tell you anything.
2010 Power Wagon
Old 02-19-2012, 10:33 AM
Color: Mineral Gray
Rep:36
camodown- hey thanks for the info. This is the first heavy duty truck I have owned. I just wanted to make sure. I don't want the tranny to fall off after a few thousand miles on it haha. Thanks!
Old 03-15-2012, 05:25 PM
toddbweaver toddbweaver is offline
Vehicle: 2012 Dodge Ram Power Wagon
toddbweaver is on a distinguished road
Default My 2012 Power Wagon transmission broke with 1000miles
Purchased it new about 4 weeks ago. It's been in the shop now for over a week. Started clunking while shifting from 2nd to 1st gear, and 1st to 2nd gear. Couple days later I got in and low and behold the check engine light was on. I called the dealer to make an appointment. The couldn't get me in until 2 days later. I also noticed that after the check engine light came on the torque converter was not engaging. The day I was to bring to the dealer I backed out of the driveway to go to work and it would only go into 4th gear. So I got turned around and luckily I only had 2 lights and a stop sign and about 30 miles to the dealer. Traveled around 40-45 with only 4th gear...not 1, 2, 3, 5, or 6 just 4th. They have now torn out the transmission ordered numerous parts and still not fixed. I've called Dodge Customer Service and demanded a new truck, new transmission, lifetime engine drivetrain warranty. My understanding from the dealer now is they have ordered a whole new transmision. I will post more when I get more information. I've had 4 dodges and no problems until this one. Maybe someone is telling me I should have kept my 09 that was perfect.
Todd
2012 Dodge Ram Power Wagon 4x4 Crew Cab, black
Old 03-15-2012, 07:33 PM
Color: Mineral Gray
Rep:36
toddbweaver- that sucks. I am sorry to hear that. That really blows. Good luck with the dealer. The whole reason I bought the power wagon was because the dealer I previously dealt with gave me the run around with my 2010 1500 when I had a problem.
Maybe you can help me with this since yours is new. When I shift out of drive and into reverse, it shifts hard. . Just curious if you have the same thing. Maybe not shift hard, but def. clunks into reverse or even drive.
Anyway, good luck with the truck. Keep me posted on the situation.
Old 03-16-2012, 10:23 AM
Default Hope this helps
Too answer your question, my truck clunked with going into gear also from park, neutral, or reverse....the mechanic who looked at the truck first said he didn't like that sound either. I don't believe that a transmission should be clucking into gear and I don't think that driveline slop is why. I've owned a number of trucks and the only time I heard clunks is when there were problems in the driveline, ujoints, differential issues.
Old 03-16-2012, 10:40 AM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:47
gusman is on a distinguished road
My 08 cummins shifts like crap. First shift from 5 to 6 in the morning sucks, I usually have to let off and then it slams into 6th then its fine. But shifts under heavy acceleration really jerk your head back. sucks..
Old 03-16-2012, 11:11 AM
Color: Mineral Gray
Rep:36
Thanks guys for the info. Maybe I will take it in a see what they think. It seems like it drives fine, but I don't want to come out some day and my truck not work. Thanks again.
Old 03-24-2012, 10:07 AM
Thumbs up Follow up from my previous post
After 2 weeks in the shop I am now back on the road. New transmission and all is well so far. They began tearing the old transmission down replacing the PCM, Pump/Valve Body, and torqure converter. I spoke with Chrysler and said that I wanted a new transmission that a truck with 1000 miles should not be used a debugging tool for chrysler. They agreed and put a new transmission in. All is well for now. Dealer was very good to work with an Chrysler did what I asked.
Todd
