Trailer Brake controller adding the factory option? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 02-26-2012, 11:05 PM
Toon tugr's Avatar
Toon tugr Toon tugr is offline
Vehicle: 2005 cummins & 2010 5.7 Hemi
Trim Level: 2005 & 2010 are SLT
Color: 2010 Silver, 2005 Burgundy / silver
Toon tugr is on a distinguished road
Originally Posted by snkmug View Post
you can buy the second harness on ebay and make the factory one you bought work. Its just a power harness, and it only needs to be programmed by the dealer it you want it to display on the evic. If you dont program it will still work like an aftermarket unit will....
Well by going aftermarket it will save me about 200 bucks overall anyhow versus the factory unit with programming.
05 Cummins 4x4 QC SB 123k,10 Hemi 4x4 QC SB 101k
sold 02 http://www.youtube.com/watch?v=i3TkO071kTk
Old 03-05-2012, 10:59 PM
yerslo yerslo is offline
yerslo is on a distinguished road
I also just ordered the factory controller from the dealership, i haven't yet checked to see if i have both harnesses, in the event that i don't have both, what exactly should i look for on ebay. thanks for any info that you can give me
Old 03-16-2012, 10:01 PM
gfviperman gfviperman is offline
Vehicle: 2011 RAM Crew
gfviperman is on a distinguished road
Installed the factory controller on my 2011 - easy 10 minute job. However, dealer wants $90 to re-flash computer so read-out will show up on dash. I even tried the donuts and they still want $90!!!
Old 03-27-2012, 05:10 PM
Wardancer Wardancer is offline
Vehicle: 2010 Dodge Ram 1500 Big Horn
Wardancer is on a distinguished road
Originally Posted by Toon tugr View Post
Well after looking around I found another way to install an aftermarket controller in the little cubby hole slot in the dash where the factory one would have gone. I found a "Curt" brake controller that is small enough to fit inside the pocket and keep the underside of the dash clean and have the controller in its designated spot. I will post pics as I do it.
Did you do your brake control like this? Let us know! Pics!
Lil Dickens Ranch
Miniature Horses
Old 06-08-2012, 03:36 PM
ajbauer ajbauer is offline
Vehicle: 2009 Dodge Ram 1500 Laramie
Color: White/Bronze
ajbauer is on a distinguished road
Default New and confused
I need some help if you or anyone can assist! I am new to this topic but for the last few days, it has been interesting trying to find an answer. I have an early production 2009.
Can the 2010 contoller be installed?
If I only have the one plug, where does the second (one from ebay) connect?
Is there a part number for it?
What are the part numbers for the controller and anything else I need?
The bezel came installed and is empty but I have the "full" tow package.
If the controller can be used, can the display in the 2009 truck be flashed ?
I apologize for slamming all of this down at once and I realize you guys have done the leg work on this issue. Just hoping somebody can cut the length of my endeavor down a bit!
Thank you all!
Old 08-01-2012, 10:32 PM
Firehawk's Avatar
Firehawk Firehawk is offline
Vehicle: 2011 Dodge Ram
Trim Level: Express RCSB/2WD
Color: Mineral Gray Metallic
Firehawk is on a distinguished road
Send a message via Yahoo to Firehawk
Does anyone have the OEM Dodge part number for it?
↑↑↑↑↑↑ My truck modifications list is located in my forum profile. → → →
Old 12-30-2012, 04:47 PM
2bornot2b 2bornot2b is offline
Vehicle: none yet
2bornot2b is on a distinguished road
Default brake controller
Need this for my 2010 2500!
Old 01-01-2013, 12:01 PM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
This has been covered many times. You need to find a post by Netman66. It's the Encyclopedia Britanica of the factory controller for trucks that have both wiring pigtails and even a tutorial on how to hook it up to trucks that just have the one pigtail.
Old 01-07-2013, 01:03 PM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
The 2009 DOES have a factory harness if you have the tow package, you just need the controller. The harness is in the same spot for all 1500's. I believe it is a 4 pin green connector.
Old 01-08-2013, 02:58 AM
TNC TNC is offline
Rep:12
Maybe I'm misreading you here, but my understanding on using the factory controller is that you must have the 2 separate plug connectors in the factory wiring harness or use the "go-around" by wiring in the wires in all 1500 pickup's wiring harnesses to make it work as outlined in Netman66's post on this issue. All Ram 1500 trucks do not have the 2 separate plugs required by the factory controller even if they have the trailer/tow package. They do, however, have the standard 4-pin connector for an aftermarket controller.
