Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 01-31-2013, 10:06 PM
Kman521 Kman521 is offline
Vehicle: 2013 Dodge Ram
Kman521 is on a distinguished road
Originally Posted by clatla View Post
I just bought another factory controller form the dealership today as I had thought mine had malfunctioned. I installed it and plugged the trailer into the truck and same issue. The trailer brakes are making a faint clicking sound. About once or twice a second. I verified when the drums were off that the magnets were energizing and releasing. Thus the clicking noise. Can someone out there please hook up to their trailer and see if their truck does the same thing.
PLEASE!
If my parts come in and my controller is installed tomorrow I will check it at the 7 pin bumper connector with a tester and post back.
I can't try the trailer right now because it's in storage.
Old 01-31-2013, 11:37 PM
clatla's Avatar
clatla clatla is offline
Color: Snow White
Rep:31
clatla is on a distinguished road
Thanks for the offer but the controller won't even turn on unless it senses the connection to the trailer. So there would not be anything at the 7 pin except the 12v.
Old 02-03-2013, 11:54 PM
Did you get your problem solved?
Maybe you have trouble with your trailer.
If you disconnect the trailer from your vehicle and check the resistance on the trailer between the electric brake wire and ground you should see 3 to 4 ohms assuming you have only two wheel braking.
Old 04-20-2013, 06:36 PM
rustysfan's Avatar
rustysfan rustysfan is offline
Vehicle: 2013 Ram crew cab
rustysfan is on a distinguished road
I seem to have the same problem, put in factory controller and it looks great, but went away last weekend and I had the gain set at 4.0 because of a lot of hills. Well my brakes were set and i didn't know it. set controller back to 0 and it towed fine. When I use the brakes with the gain at 0 the unit reads 1.0 then 2.0 then max at 3.0. Had the dealer set it up when i installed it so it would work with the computer. Now they tell me there is nothing wrong with it and the comp. knows how much brake to use. Any thoughts?
Old 04-20-2013, 07:35 PM
Mine is a 13, not a 12 but I connected my open car trailer while it was empty and the brakes worked fine except they were locking up when I pushed the brake pedal because of no load on the trailer. Even when it was set for 5 the trailer brakes were not on while driving down the road. I did set it to 1 and the brakes no longer locked up with the empty trailer. Later in May I will be pulling the trailer with a car on it so I'll see then but I don't think there will be a problem.
Old 01-22-2014, 07:30 PM
jsnow499 jsnow499 is offline
Vehicle: 12 1500
Trim Level: st
Color: red
jsnow499 is on a distinguished road
i have been searching looking for this add on harness ebay and such any idea where to get one I have the one plug instead of two
