Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 02-16-2012, 06:31 PM
Fatkat4 Fatkat4 is offline
Vehicle: 2006 quadcab 1500
Color: red
Fatkat4 is on a distinguished road
Default front end vibration
Hello i am new here so here is my problem . I have a 2006 ram 1500 quadcab 5.7 39000 miles . when i step on my brakes it shakes violently . I thought it might be front rotors but here is where i am puzzled , i also get a slight vibration just driving straight no brakes if i make a right turn and touch the brakes it shakes even worse also if i am in a parking lot and turn the wheel all the way to the left and go slow i get a sorta creaking noise also sometimes in the morning when its cold ill hear almost a whistle type noise but cant figure out where it is coming from . all of my virbration feel like its coming from my left front wheel , any help is greatly appreciated thank you
Jason
Old 02-16-2012, 07:48 PM
Knuckles Knuckles is offline
Vehicle: 2003 Dodge Ram 2500 5.7 4x4
Trim Level: SLT Heavy Duty
Color: Gun Metal Gray
Knuckles is on a distinguished road
Check your drivers side axle u-joint?
Old 02-16-2012, 08:01 PM
Color: red
how do i check the axle ujoint to see if its bad ,
Old 02-17-2012, 01:28 AM
Whoops, I overlooked you had a 1500 sorry. Most common things for what you are describing are warped or unevenly worn rotors or your tires can be way out of balance.
Old 02-17-2012, 02:30 PM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
Like above tires or rotors.
It's a truck, not a cream puff
Old 02-17-2012, 05:50 PM
Color: red
ok thanks guys i will be changing rotors and brakes tomorrow , and getting tires balanced also , I sure hope it fixes it
Old 02-17-2012, 06:53 PM
06 BigHorn's Avatar
Rep:153
If the tires are cupped you'll still have your problem even after being balanced
Old 02-17-2012, 07:01 PM
Color: red
ok will check that also
Old 02-18-2012, 12:07 PM
Color: red
Thank you all , It was the brakes and rotors
