lifting my truck - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 02-16-2012, 08:27 PM
tmchlds's Avatar
tmchlds tmchlds is offline
Vehicle: 2000 Dodge Ram 1500 V6 Magnum
Color: Maroon
tmchlds is on a distinguished road
Default lifting my truck
I am wanting to lift my truck with a 2" lift kit, my truck is not a 4X4, is it even possible to put a lift on it? If so what is the best type to do and where can i get it from?
Old 02-25-2012, 02:28 PM
dezertrunner dezertrunner is offline
Vehicle: 2001 Ram
Trim Level: Base
Color: Blue
dezertrunner is on a distinguished road
Best type? Long travel suspension. You'll run circles around any 4x4 on this site. Be prepared to spend $5-15 grand.
Coil spacers or spindles are really your only option for what you are looking for. They range between $20-300.
Old 03-09-2012, 06:27 AM
ramfnmadman ramfnmadman is offline
Vehicle: 1997 Dodge 1500 4x4
Trim Level: SLT Laramie
ramfnmadman is on a distinguished road
Thats a pretty bold statement depends on what your idea of running circles is?
Old 03-12-2012, 10:16 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Color: Green
Rep:31
Big Green V10 is on a distinguished road
Could do a body lift but yeah spacer lift http://www.ebay.com/itm/1994-2011-Dodge-Ram-1500-Front-3-Lift-Leveling-Kit-2WD-PRO-/250992000895?pt=Motors_Car_Truck_Parts_Accessories &fits=Make%3ADodge&hash=item3a7049ff7f&vxp=mtr
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
Old 04-09-2012, 08:10 PM
rayzram rayzram is offline
Vehicle: 2001 Dodge Ram 1500
rayzram is on a distinguished road
Don't forget about the back. On my 01 2wd I lifted the front 2.5" (with a Daystar poly coil spacer) and had to use a 1.5" spacer block in the rear for it to be level. Otherwise the front would've been higher. I can run 33's now but I'm having issues getting it aligned...hope it goes well!
