Old 02-16-2012, 09:39 PM
bobak2 bobak2 is offline
Vehicle: 2012 Dodge Ram 1500 Red Wings
Trim Level: Red Wings Edition
bobak2 is on a distinguished road
Default Hid
Anyone have any suggestions on a good HID kit that wont break the bank because im going to be getting two kits on for my hi/lo and one for my fogs. Alot of my friends here are getting DDM kits but im unsure if i want to go with them for my truck. They are good on my bike but idk about for my truck. Any input would be great. Thanks in advance
Old 02-19-2012, 01:09 PM
silverstreak88 silverstreak88 is offline
Vehicle: 2007 Dodge Ram 1500 4x4
Color: Black, Silver
Rep:13
silverstreak88 is on a distinguished road
Be carefull with the HID kits, Ive senn alot of kits in the new Rams that will flicker and flash when you go to turn them on.
Old 02-19-2012, 01:42 PM
dezertrunner dezertrunner is offline
Vehicle: 2001 Ram
Trim Level: Base
Color: Blue
dezertrunner is on a distinguished road
DDM, run a relay harness.
Old 02-19-2012, 07:12 PM
ok thanks for the info. Is the relay the same as the error code eliminator or something different? and if its different do i need them both?
Old 02-23-2012, 12:59 AM
Vehicle: 2001 Ram
Trim Level: Base
Color: Blue
No, the relay keeps the ballasts/bulbs from burning out due to the crappy wiring in the truck. HID ballasts draw less amperage then Halogen bulbs, however when they first start that have what's called "Flash" current. For about half a second they pull around 12-15 amps, which is far more then the trucks factory wiring can handle.
No clue if you need a "code eliminator". All they are are some .20 cent resistors.
