Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 02-16-2012, 10:22 PM
mcochran1868 mcochran1868 is offline
Vehicle: 2006 Dodge Ram SLT Crew Cab
Color: Metallic Black
mcochran1868 is on a distinguished road
Default Front Suspension Noise
I just bought a 2006 Ram 1500 5.7 HEMI 4x4 and when I take bumps slow and the truck shifts left to right I hear a dull squeak noise from the front right suspension. I have looked at the ball joints and tie rods and all looks clean and the rubber looks great. I can recreate the noise by picking up on the front end under the passenger fender well. My first thought is the previous owner put leveling spacers on the front and did not grease properly. I was just trying to figure out if there is any other possible explanation for that noise. Like I said it is a very dull noise, sounds like rubber on metal. All thoughts would be appreciated.
Old 02-17-2012, 01:34 PM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
If your truck has Monroe struts its the plastic bump stop located on the strut shaft. Squirt some white lithium grease above that rubber stop from all angles.
Or your strut is blown
It's a truck, not a cream puff
Old 02-17-2012, 01:52 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Mine makes a groaning sound from the front. Don't know, control arm bushings?
Old 02-17-2012, 11:57 PM
Pinpointed the noise tonight when I finally got the time, left bushing on the upper A arm. All is well structurally but goodness that noise is going to drive me crazy until I can get in there and replace is with a new urethane one. Thank you for the info!
Old 05-16-2012, 08:51 PM
waysiders waysiders is offline
Vehicle: 2008 Dodge Ram SLT Quad Cab
Color: Slate Grey
waysiders is on a distinguished road
Thumbs up Same issue
I have the exactly same problem and it's been driving me nuts. I can recreate it the same way you did by lifting up under the wheel well. Only difference is that mine is on the drivers side. I haven't been able to pinpoint the source. Do you happen to have any pics of the location you pinpointed? Please let me know if the urethane bushings fix your issue.
