Hemi TB does NOT fit on 2008+ 4.7L - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 02-17-2012, 10:23 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Default Hemi TB does NOT fit on 2008+ 4.7L
A member on here with a late model Hemi sent me a measurement of his stock TB bolt spacing and it was about 3.1875" square. My 2008+ 4.7L stock TB bolt spacing is about 2.75" square. So it will not bolt up.
Otherwise, they basically look identical in design as far as layout and shape, etc. The hemi TB is metal and the 4.7L TB is plastic. Obviously the HEMI one is larger bore, I think 80mm. IIRC the 4.7L TB is like 74mm. I was told the stock 2008+ 4.7L intake manifold opening was 80mm. So, theoretically, you could make some sort of adapter plate to bolt the hemi TB to the 4.7L manifold, and have as large of a TB as you could possibly have on the stock manifold. The wiring harness connector would likely need modified/changed as well, but I'm guessing it is very doable, as they are both fly by wire and I think have the same wires. So it looks like it would take an adapter plate and some minor wiring change to the connecter, and then it MIGHT work. Who knows though, it may have no signal or not respond correctly...
So, I'm abandoning this project, at least for now. I may see if it'd work down the road...just wanted to share the info, I know some were wondering the same thing.
Sean
Old 02-23-2012, 11:57 PM
mblatz mblatz is offline
Vehicle: 2008 Ram 1500
mblatz is on a distinguished road
Hey Sean, just wanted to let you know, i am currently CAD drafting a new adapter plate, and have a question for ya. Would you be able to ask your friend with the 80mm TB if there is a rubber gasket or seal, and if there is, what the inside and outside dimensions of the groove would be, so i can factor that into the design?
Old 02-24-2012, 12:02 AM
snrusnak's Avatar
Rep:1388
He is a member on here, I think his name is "CHVYKLLR" or somethiing like that. Send him a PM, he is very nice and helpful...
Sean
Old 02-24-2012, 12:04 AM
snrusnak's Avatar
Rep:1388
Also, if you make a plate please keep me updated. I would have liked to continue on with this but it would have taken me a lot of time and I have other priorities currently...
Sean
Old 03-09-2012, 11:36 AM
snrusnak's Avatar
Rep:1388
Did you ever get anywhere with this?
Sean
Old 03-09-2012, 12:38 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
If you need measuements i wouldnt mind pulling my tb off and mesuring for ya either
lmk
2011 Big Horn 4x4 -SnowWhite-
Old 03-09-2012, 12:41 PM
snrusnak's Avatar
Rep:1388
If someone actually gets a file drawn, I can probably get a piece of aluminum machined (friend has the tools to do it). The we could see if it'd work...
Sean
