Old 02-17-2012, 01:45 PM
lilbully lilbully is offline
Vehicle: 2000 dodge ram 1500
lilbully is on a distinguished road
Default tranny conversion advice
I have a 2000 dodge ram 4x4 but the tranny is going and I have a tranny from a 3500 94 dodge conversion van that is 2wd can i convert the 2wd tranny to 4wd by using my transfer case from my 4x4 truck and how can I do that because the 2wd tranny is mint doesn't slip nothing so how do I do it I was told I could but wasn't told how please give me your input.
Old 02-17-2012, 06:07 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Well you would take the van transmission and remove the OD assembly then remove the OD assembly from the 4WD unit and then just bolt it up to the 2wd transmission, being sure that the transmissions have the same mount pattern and being sure to use new gaskets etc...
The issue you will probably have will be with the electronics, the 2000 Dodge Ram has an electronic governor and the 94 Dodge Ram Van has a hydraulic governor, though the transmission will work the ECM from your pickup will probably get confused when it is requesting the signals from the electronic sensor in the transmission which the 94 doesn't have. The 94 only has a neutral safety switch, od solenoid and if equipped with a lock up tcc then a tcc solenoid. All in all it will be either 2 or 3 pins. The 96 trucks is when they started using an E model transmission instead of an H. Provided the plug fits I think you can just swap valve bodies but I am not 100% sure.
Oh you might have difficulty removing the OD assembly, the intermdiate shaft has a slight tendency to get it self stuck in the OD unit and if this has occured you will have to completely take apart the transmission, don't ever try to force the unit off the intermediate shaft.
