Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 02-17-2012, 12:47 PM
Tcroc's Avatar
Tcroc Tcroc is offline
Vehicle: 2008 Dodge ram
Tcroc is on a distinguished road
Default Buying a hitch along with accessories
I have a 08 1500 4.7L quad cab without a the tow package. Ive done a little bit a research and want to make sure i have everything right before making my purchase. Ill be towing a dolly or trailer along with my race car about 4 hours away from my place. The car weighs about 3000lbs or less and ill be renting a trailer or dolly from uhaul.
Now uhaul said they would be able to take care of everything with ordering the parts and accessories along with install. Class III hitch, ball mount, wiring harness, prodigy p2 brake controller.
Am I missing anything? Is there better products out there than i listed?
Old 02-17-2012, 02:01 PM
IH Scout Driver IH Scout Driver is offline
Vehicle: 2012 Ram 3500 Crew Cab
Rep:42
IH Scout Driver is on a distinguished road
You don't need the brake controller if you will be utilizing a u-haul trailer. Unless u-haul has revamped their trailers nationwide in the past 6 months, they all have a hydraulic surge actuator for the full car haulers; dollys have no brakes. This means that no extra electronic controllers are needed. If you have your own trailer with electric brakes, then by all means; get the brake controller.
Essentially, you just need the frame mount Class III hitch, wiring harness and ball mount. Be sure to utilize the 2" balls for the u-haul trailers as they are made for 1-7/8 & 2 with extra slop on the 1-7/8.
HTH
Old 02-17-2012, 03:14 PM
Tcroc's Avatar
thanks for the response. Ill eventually get my own trailer but for now ill be renting one. Ill hold off on the brake controller till then.
Thanks again
Old 02-17-2012, 07:04 PM
Kong's Avatar
Kong Kong is offline
Vehicle: 2012 Toyota Tundra
Trim Level: SR5
Color: Metalic Grey
Kong is on a distinguished road
Did not just about all of them come with a receiver hitch mounted already?
Old 02-17-2012, 07:49 PM
Rep:42
Tcroc,
You are welcome, hope it helps you out in the long run.
Kong,
No, not all trucks come with a receiver hitch or even a bumper capable of towing anymore. It is cheaper to produce a truck without those features, so it is an add-on for the end user; especially with 1/2 ton trucks. Apparently, there are too many city folk getting trucks for looks than for use.
Old 02-18-2012, 12:11 AM
RedRiverRam's Avatar
RedRiverRam RedRiverRam is offline
Vehicle: 2011 Ram
Rep:41
RedRiverRam is on a distinguished road
Not mentioned here but if you do a lot of connecting to the trailer alone, get yourself a rear view camera. Best invention since sliced bread for those of us that tow often and have to hook-up alone.
My OTHER rides are hot air balloons - Coyote Moon and Coyote Rising - aka Dos Coyotes!
Old 02-18-2012, 12:15 AM
Kong's Avatar
Trim Level: SR5
Color: Metalic Grey
It just seamed odd. The last time I was at a dealer was in 07 looking at new ones, and every one on the lot had them already installed. I just assumed they all came that way.
Old 02-18-2012, 12:30 AM
Rep:2657
Just my opinion
Buy a class 4 hitch receiver
i always go a bit higher than what is required & i never have to wonder if it is enough
Old 02-19-2012, 12:22 PM
Tcroc's Avatar
Just my opinion
I thought about a class 4 hitch but i didn't see the option at uhaul. I did notice you can change the max towing weight. I guess I can purchase the hitch elsewhere.
Old 02-19-2012, 01:48 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
I'm not sure I would go to Uhaul for my receiver, the ball and mount, maybe and maybe even the wiring harness but not the receiver (esp. if it's not a Class IV). Go get the MOPAR receiver and have it installed by your dealer (I think it requires the bed to be lifted off temporarily now). You'll be happy you did in the long run.
Ditto on the back-up camera as well. If I did more towing/hooking up by myself, I'd have one in a instant! They are only $319 in parts + install if you already have a touch screen radio and that is about 1/2 the cost of a new bumper if you hit the tongue hooking up!
