Old 02-21-2012, 11:19 PM
hemiram08 hemiram08 is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: SLT Sport Package
Color: The '09 blue
hemiram08 is on a distinguished road
do you have to manually switch on the fan or will it automatically turn on at a certain temp.
Old 02-22-2012, 07:50 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^depends how you set it up. It is possible to have it switch operated, and it is also possible to have it operate by a preset coolant temperature via a fan controller. It all depends on how you wire it up. I've also seen people have a fan controller AND switch so they could turn it on whenever they want, and still have it come on automatically (if they forget to turn it on).
Sean
Old 02-22-2012, 07:45 PM
Color: The '09 blue
good to know, thank you
Old 02-22-2012, 08:53 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
Yeah, as of today I wired the manual switch in so now it is both ways.
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 02-24-2012, 12:08 AM
dodgefan dodgefan is offline
Vehicle: 03 dodge ram 2500 4x4 HD
Trim Level: slt hd
Color: blue
dodgefan is on a distinguished road
keep an eye on the temp in the summer works great in the cool season but mine couldnt keep up in summer had to remove.
Old 02-24-2012, 08:15 AM
05ram's Avatar
Trim Level: .:R
Color: UGM
Rep:145
Thanks, will do. I guess if I had too I could add the stock fan back on for the "hot" weather, then there would be 3 fans!
Old 02-24-2012, 08:23 AM
snrusnak's Avatar
Rep:1385
If you have an electric fan that is properly sized then you shouldn't have any cooling issues. Just about every car anymore has electric fan(s) instead of mechanical, and they have less cooling problems than cars used to. Now there are other reasons for this as well, but my point is a properly designed cooling system (including the fan) will not allow you to overheat. Too big is always better than too small though. (that's what she said...)
Sean
Old 02-24-2012, 10:27 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Not a sweat w/ my Mark VIII in Tucson 100-120+ temps. Cooling myself was another thing which is prob' why i did not drive the truck much during summer last year.
Old 02-24-2012, 12:06 PM
05ram's Avatar
Trim Level: .:R
Color: UGM
Rep:145
I don't think the 183 should have a problem, it uses the Black Magic 180 extreme, one of their best fans.
Old 04-13-2012, 06:13 AM
KwS-Blackout's Avatar
KwS-Blackout KwS-Blackout is offline
Vehicle: 2005 Ram 1500 Daytona
Trim Level: Daytona
Color: Go Mango
KwS-Blackout is on a distinguished road
I know this is almost 2 months old but, 05ram did you do a 180 thermostat on top of the fan, or are you using the stock setup? also what controller are you using to run the fan? Im thinking of doing a Mark 8 lincoln fan with a Hayden controller. Any thoughts on this setup?
