Old 02-18-2012, 12:24 AM
wulfgar's Avatar
wulfgar wulfgar is offline
Vehicle: 1994 ram 1500 4x4
Color: primer gray atm
wulfgar is on a distinguished road
Default Leaf spring questions
On my 94 1500 4x4 I noticed my leaf springs were all most flat.
I got a set off a 96 that was wrecked. They are 4+1 with a 3" block. Mine are 3+1 with a 6" block. Can I keep my block or should I use the 3" one?
And will I have to replace the shocks?
Thanks
Old 02-18-2012, 12:31 PM
dusted72's Avatar
dusted72 dusted72 is offline
Vehicle: 1998 Dodge Ram
Trim Level: SS/T
dusted72 is on a distinguished road
I don't see why you couldn't use your block.
Explosions are cool.
Old 02-19-2012, 01:04 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
The shocks should have more than enough travel and there shouldn't be any problem using your blocks. There may be a difference in the u-bolts. If so send me a PM because I have a set hanging on the rafter of my shed.
Old 02-26-2012, 01:21 AM
wulfgar's Avatar
Well I got the spring on the driver side swapped out. I wasn't able to use my old block my u bolts were about an inch short. As a temp fix I stacked the two blocks I got with the springs. There about an inch or so shorter. Now my bumper on that side is waist high. I'm gonna take my old blocks and grind out the weld were they stacked a 2" on a 4" block. With the extra spring in my new springs it should put it close to where it was still be taller. 16" square u-bolts are hard to find locally. Napa can have some made for me but it will take a week or more. If I keep my blocks as they are I will have to much rake.
